I just installed the lates HA OS version 2021.12.1and the compagnon App.
I realized that If I log as a normal user on the compagnon app I cannot access the app settings
So for example I would not be able to revoke the tracking from the app. But more importantly I cannot enable any sensor as a normal user. I need to log as the administrator.
The settings for the app is under configuration>compagnon app configuration.
The configuration menu only shows up if you are an administrator. Both menu should be separated as it seemed to be the case in earlier versions (from the snapshot of the help I can find on internet)
I understand that you should be an administrator to change any setting of the server.
But not for the settings of the application. The owner of the phone should be able to change the settings of the app. Otherwise you have to give administrator right to any one you give access to your sever through the phone.
This can be a big security issue depending on where you use the server (in a home, in an office,…) and who you give access to (teenager,…)
Is there a way to access the settings of the app without being an administrator.
Otherwise would it be possible to change this behavior.
