I’ve attached logs below:
I do see some media player related errors there but I’m not sure what they mean…
07-21 13:40:07.124 6471 6471 E IPCThreadState: attemptIncStrongHandle(98): Not supported
07-21 13:40:07.125 6471 11574 D BufferQueueProducer: [VRI[AssistActivity]#10(BLAST Consumer)10](id:19470000000a,api:1,p:6471,c:6471) connect: api=1 producerControlledByApp=true
07-21 13:40:07.125 6471 6471 D VRI[AssistActivity]: registerCallbacksForSync syncBuffer=false
07-21 13:40:07.128 6471 11574 D VRI[AssistActivity]: Received frameCommittedCallback lastAttemptedDrawFrameNum=1 didProduceBuffer=true syncBuffer=false
07-21 13:40:07.129 6471 11574 W Parcel : Expecting binder but got null!
07-21 13:40:07.129 6471 6471 D VRI[AssistActivity]: draw finished.
07-21 13:40:07.132 6471 6471 I Quality : Skipped: false 1 cost 14.925196 refreshRate 8333333 bit true processName io.homeassistant.companion.android
07-21 13:40:07.137 6471 6471 D VRI[AssistActivity]: registerCallbacksForSync syncBuffer=false
07-21 13:40:07.139 6471 11574 D VRI[AssistActivity]: Received frameCommittedCallback lastAttemptedDrawFrameNum=3 didProduceBuffer=true syncBuffer=false
07-21 13:40:07.139 6471 6471 D VRI[AssistActivity]: draw finished.
07-21 13:40:07.169 6471 6471 D VRI[AssistActivity]: onFocusEvent true
07-21 13:40:07.169 6471 6471 D VRI[AssistActivity]: send msg MSG_WINDOW_FOCUS_CHANGED with caller android.view.ViewRootImplExtImpl.markAndDumpWindowFocusChangeMsg:956 android.view.ViewRootImpl.windowFocusChanged:9837 android.view.ViewRootImpl$WindowInputEventReceiver.onFocusEvent:9550 android.os.MessageQueue.nativePollOnce:-2 android.os.MessageQueue.next:349 android.os.Looper.loopOnce:186 android.os.Looper.loop:351 android.app.ActivityThread.main:8416 java.lang.reflect.Method.invoke:-2 com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run:584 com.android.internal.os.ZygoteInit.main:1013 <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack>
07-21 13:40:07.169 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged true mUpcomingWindowFocus true mAdded true
07-21 13:40:07.173 6471 24187 D TrafficStats: tagSocket(116) with statsTag=0xffffffff, statsUid=-1
07-21 13:40:07.195 6471 24187 D WebSocketRepository: Websocket: onOpen
07-21 13:40:07.195 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.196 6471 11566 D WebSocketRepository: Message number null received
07-21 13:40:07.196 6471 11566 D WebSocketRepository: Auth Requested
07-21 13:40:07.200 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.200 6471 11566 D WebSocketRepository: Message number null received
07-21 13:40:07.200 6471 6471 D WebSocketRepository: Sending message 14: {type=supported_features, id=14, features={coalesce_messages=1}}
07-21 13:40:07.200 6471 6471 D WebSocketRepository: Sending message 15: {type=get_config, id=15}
07-21 13:40:07.200 6471 6471 D WebSocketRepository: Message number 15 sent
07-21 13:40:07.203 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.204 6471 11566 D WebSocketRepository: Message number 14 received
07-21 13:40:07.206 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.207 6471 11566 D WebSocketRepository: Message number 15 received
07-21 13:40:07.208 6471 6471 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
07-21 13:40:07.208 6471 6471 D WebSocketRepository: Sending message 16: {type=assist_pipeline/pipeline/get, id=16}
07-21 13:40:07.208 6471 6471 D WebSocketRepository: Message number 16 sent
07-21 13:40:07.212 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.212 6471 23422 D WebSocketRepository: Message number 16 received
07-21 13:40:07.213 6471 6471 D AudioRecord: getMinFrameCount 1792
07-21 13:40:07.213 6471 6471 D AudioRecordExtImpl: AudioRecordExtImpl init
07-21 13:40:07.213 6471 6471 D AudioRecordExtImpl: audiorecordTest
07-21 13:40:07.213 6471 6471 D AudioRecord: set(): inputSource 1, sampleRate 44100, format 0x1, channelMask 0x10, frameCount 17920, notificationFrames 0, sessionId 0, transferType 0, flags 0, attributionSource AttributionSourceState{pid: -1, uid: 10276, packageName: io.homeassistant.companion.android, attributionTag: (null), token: , renouncedPermissions: [], next: []}uid -1, pid -1
07-21 13:40:07.213 6471 6471 D AudioRecord: set(): mSessionId 0
07-21 13:40:07.213 6471 6471 D ListServiceUtils: checkInListByUid module:audio-boost-blacklist uid:10276 cost 63us return 0
07-21 13:40:07.213 6471 6471 D AudioRecordExtImpl: doSmoothBoost, set audioapp task boost, pid=6471, tid=24196, enable=1, ret=0
07-21 13:40:07.213 6471 6471 D AudioRecord: set(): 0xb4000077b3a85900, Create AudioRecordThread, tid = 24196
07-21 13:40:07.213 6471 6471 D ListServiceUtils: checkInListByUid module:audio-boost-blacklist uid:10276 cost 130us return 0
07-21 13:40:07.214 6471 6471 D AudioRecordExtImpl: doSmoothBoost, set audioapp task boost, pid=6471, tid=6471, enable=1, ret=0
07-21 13:40:07.222 6471 6471 I AudioRecord: openRecord_l: 0xb4000077b3a85900, mCblk = 0x77b158f000
07-21 13:40:07.223 6471 6471 D AudioRecord: start(3273): sync event 0 trigger session 0
07-21 13:40:07.232 6471 6471 D ListServiceUtils: checkInListByUid module:audio-boost-blacklist uid:10276 cost 83us return 0
07-21 13:40:07.233 6471 6471 I AudioRecord: start(3273): return status 0
07-21 13:40:07.233 6471 23422 D AudioRecord: getMinFrameCount 1792
07-21 13:40:07.233 6471 6471 D WebSocketRepository: Sending message 17: {type=assist_pipeline/run, start_stage=stt, end_stage=tts, input={sample_rate=44100}, conversation_id=null, pipeline=01h4pg6fhcs77yha9y0h4bnryk, id=17}
07-21 13:40:07.233 6471 23422 D ListServiceUtils: checkInListByUid module:audio-boost-blacklist uid:10276 cost 61us return 0
07-21 13:40:07.233 6471 23422 D AudioRecordExtImpl: doSmoothBoost, set audioapp task boost, pid=6471, tid=23422, enable=1, ret=0
07-21 13:40:07.233 6471 6471 D WebSocketRepository: Message number 17 sent
07-21 13:40:07.234 6471 6471 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
07-21 13:40:07.234 6471 6471 D WebSocketRepository: Sending message 18: {type=assist_pipeline/pipeline/list, id=18}
07-21 13:40:07.234 6471 6471 D WebSocketRepository: Message number 18 sent
07-21 13:40:07.235 6471 6471 I Quality : Skipped: false 2 cost 20.083755 refreshRate 8252507 bit true processName io.homeassistant.companion.android
07-21 13:40:07.239 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.240 6471 23421 D WebSocketRepository: Message number 17 received
07-21 13:40:07.240 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.245 6471 11625 D WebSocketRepository: Message number 17 received
07-21 13:40:07.247 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:07.249 6471 11625 D WebSocketRepository: Message number 18 received
07-21 13:40:07.252 6471 6471 I Quality : Skipped: false 1 cost 12.338893 refreshRate 8254675 bit true processName io.homeassistant.companion.android
07-21 13:40:08.176 6471 6471 D OplusScrollToTopManager: io.homeassistant.companion.android/io.homeassistant.companion.android.assist.AssistActivity,This DecorView@4e2d21b[AssistActivity] change focus to true
07-21 13:40:14.754 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:14.756 6471 11625 D WebSocketRepository: Message number 17 received
07-21 13:40:14.757 6471 6471 D AudioRecord: stop(3273): mActive:1
07-21 13:40:14.758 6471 6471 D AudioRecord: call mAudioRecord->stop()
07-21 13:40:14.761 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.765 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.767 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.768 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.769 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.770 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.772 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.773 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.774 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.775 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.776 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.777 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.778 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.779 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.780 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.781 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.782 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.783 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.784 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.785 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.786 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.787 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.788 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.789 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.790 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.791 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.792 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.793 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.794 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.795 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.796 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.797 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.798 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.799 6471 23422 E AudioRecord-JNI: Error -38 during AudioRecord native read
07-21 13:40:14.799 6471 6471 D AudioRecord: call AudioRecordThread pause()
07-21 13:40:14.799 6471 6471 D AudioRecord: stop(3273) done
07-21 13:40:14.799 6471 6471 D AudioRecord: stop(3273): mActive:0
07-21 13:40:14.799 6471 6471 I AudioRecord: ~AudioRecord(3273): mStatus 0
07-21 13:40:14.800 6471 6471 D ListServiceUtils: checkInListByUid module:audio-boost-blacklist uid:-1 cost 151us return 0
07-21 13:40:14.800 6471 6471 D AudioRecordExtImpl: doSmoothBoost, set audioapp task boost, pid=6471, tid=6471, enable=0, ret=0
07-21 13:40:14.800 6471 6471 D AudioRecordExtImpl: doSmoothBoost, set audioapp task boost, pid=6471, tid=23422, enable=0, ret=0
07-21 13:40:14.800 6471 6471 D AudioRecordExtImpl: doSmoothBoost, set audioapp task boost, pid=6471, tid=24196, enable=0, ret=0
07-21 13:40:14.801 6471 6471 I Quality : Skipped: false 4 cost 39.143265 refreshRate 8261370 bit true processName io.homeassistant.companion.android
07-21 13:40:14.814 6471 6471 I Quality : Skipped: false 1 cost 10.12923 refreshRate 8260347 bit true processName io.homeassistant.companion.android
07-21 13:40:15.517 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:15.767 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:15.816 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:15.867 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:15.917 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:15.970 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.018 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:16.020 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.021 6471 23422 D WebSocketRepository: Message number 17 received
07-21 13:40:16.023 6471 23422 D WebSocketRepository: Message number 17 received
07-21 13:40:16.025 6471 6471 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
07-21 13:40:16.025 6471 6471 D ServerConnectionInfo: Using external URL
07-21 13:40:16.029 6471 11625 D WebSocketRepository: Unsubscribing from assist_pipeline/run with data {start_stage=stt, end_stage=tts, input={sample_rate=44100}, conversation_id=null, pipeline=01h4pg6fhcs77yha9y0h4bnryk}
07-21 13:40:16.030 6471 11625 D WebSocketRepository: Sending message 19: {type=unsubscribe_events, subscription=17, id=19}
07-21 13:40:16.030 6471 11625 D WebSocketRepository: Message number 19 sent
07-21 13:40:16.031 6471 23419 V MediaHTTPService: MediaHTTPService(android.media.MediaHTTPService@b8e8ba3): Cookies: null
07-21 13:40:16.040 6471 24187 D WebSocketRepository: Websocket: onMessage (text)
07-21 13:40:16.040 6471 11625 D WebSocketRepository: Message number 19 received
07-21 13:40:16.044 6471 12368 V MediaHTTPService: makeHTTPConnection: CookieHandler (java.net.CookieManager@c927dd1) exists.
07-21 13:40:16.045 6471 12368 V MediaHTTPService: makeHTTPConnection(android.media.MediaHTTPService@b8e8ba3): cookieHandler: java.net.CookieManager@c927dd1 Cookies: null
07-21 13:40:16.045 6471 12368 D MediaHTTPConnectionExtImpl: app io.homeassistant.companion.android
07-21 13:40:16.046 6471 12368 D MediaHTTPConnectionExtImpl: mNeedSetTimeout=false
07-21 13:40:16.047 6471 24187 D WebSocketRepository: Websocket: onClosing code: 1000, reason:
07-21 13:40:16.047 6471 24187 D WebSocketRepository: Websocket: onClosed
07-21 13:40:16.070 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.106 6471 12368 D TrafficStats: tagSocket(116) with statsTag=0xffffffff, statsUid=-1
07-21 13:40:16.120 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.174 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.223 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.276 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.324 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.376 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.426 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:16.430 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:18.438 6471 11543 D MediaHTTPConnection: getSize mTotalSize=273684
07-21 13:40:18.553 6471 6471 W AidlConversion: aidl2legacy_AudioChannelLayout_audio_channel_mask_t: no legacy output audio_channel_mask_t found for AudioChannelLayout{layoutMask: 16}
07-21 13:40:19.537 6471 6471 D CompatibilityChangeReporter: Compat change id reported: 150939131; UID 10276; state: ENABLED
07-21 13:40:23.655 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:23.663 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:24.912 6471 6471 V MediaPlayer: resetDrmState: mDrmInfo=null mDrmProvisioningThread=null mPrepareDrmInProgress=false mActiveDrmScheme=false
07-21 13:40:24.913 6471 6471 V MediaPlayer: cleanDrmObj: mDrmObj=null mDrmSessionId=null
07-21 13:40:24.913 6471 6471 D MediaPlayer: _release native called
07-21 13:40:24.930 6471 6471 D MediaPlayer: _release native finished
07-21 13:40:24.930 6471 6471 W MediaPlayer: mediaplayer went away with unhandled events
07-21 13:40:29.384 6471 6471 D VRI[AssistActivity]: onFocusEvent false
07-21 13:40:29.384 6471 6471 D VRI[AssistActivity]: send msg MSG_WINDOW_FOCUS_CHANGED with caller android.view.ViewRootImplExtImpl.markAndDumpWindowFocusChangeMsg:956 android.view.ViewRootImpl.windowFocusChanged:9837 android.view.ViewRootImpl$WindowInputEventReceiver.onFocusEvent:9550 android.os.MessageQueue.nativePollOnce:-2 android.os.MessageQueue.next:349 android.os.Looper.loopOnce:186 android.os.Looper.loop:351 android.app.ActivityThread.main:8416 java.lang.reflect.Method.invoke:-2 com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run:584 com.android.internal.os.ZygoteInit.main:1013 <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack>
07-21 13:40:29.384 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged true mUpcomingWindowFocus false mAdded true
07-21 13:40:30.387 6471 6471 D OplusScrollToTopManager: io.homeassistant.companion.android/io.homeassistant.companion.android.assist.AssistActivity,This DecorView@4e2d21b[AssistActivity] change focus to false
07-21 13:40:36.682 6471 6471 D VRI[AssistActivity]: onFocusEvent true
07-21 13:40:36.683 6471 6471 D VRI[AssistActivity]: send msg MSG_WINDOW_FOCUS_CHANGED with caller android.view.ViewRootImplExtImpl.markAndDumpWindowFocusChangeMsg:956 android.view.ViewRootImpl.windowFocusChanged:9837 android.view.ViewRootImpl$WindowInputEventReceiver.onFocusEvent:9550 android.os.MessageQueue.nativePollOnce:-2 android.os.MessageQueue.next:349 android.os.Looper.loopOnce:186 android.os.Looper.loop:351 android.app.ActivityThread.main:8416 java.lang.reflect.Method.invoke:-2 com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run:584 com.android.internal.os.ZygoteInit.main:1013 <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack>
07-21 13:40:36.683 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged true mUpcomingWindowFocus true mAdded true
07-21 13:40:37.063 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:37.063 6471 6471 V AutofillManager: requestHideFillUi(null): anchor = null
07-21 13:40:37.072 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:37.075 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged false mUpcomingWindowFocus true mAdded true
07-21 13:40:37.093 6471 6471 I Quality : Skipped: true 2 cost 18.383856 refreshRate 8255135 bit true processName io.homeassistant.companion.android
07-21 13:40:37.122 6471 6471 D VRI[AssistActivity]: onFocusEvent false
07-21 13:40:37.122 6471 6471 D VRI[AssistActivity]: send msg MSG_WINDOW_FOCUS_CHANGED with caller android.view.ViewRootImplExtImpl.markAndDumpWindowFocusChangeMsg:956 android.view.ViewRootImpl.windowFocusChanged:9837 android.view.ViewRootImpl$WindowInputEventReceiver.onFocusEvent:9550 android.os.MessageQueue.nativePollOnce:-2 android.os.MessageQueue.next:349 android.os.Looper.loopOnce:186 android.os.Looper.loop:351 android.app.ActivityThread.main:8416 java.lang.reflect.Method.invoke:-2 com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run:584 com.android.internal.os.ZygoteInit.main:1013 <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack> <bottom of call stack>
07-21 13:40:37.140 6471 6471 D VRI[AssistActivity]: handleWindowFocusChanged mWindowFocusChanged true mUpcomingWindowFocus false mAdded true
07-21 13:40:37.144 6471 6471 D VRI[AssistActivity]: setWindowStopped stopped:true
07-21 13:40:37.169 6471 11544 D VRI[AssistActivity]: dispatchAppVisibility visible:false
07-21 13:40:37.171 6471 6471 D OplusScrollToTopManager: io.homeassistant.companion.android/io.homeassistant.companion.android.assist.AssistActivity,window dying
07-21 13:40:37.171 6471 6471 D OplusScrollToTopManager: io.homeassistant.companion.android/io.homeassistant.companion.android.assist.AssistActivity,unregisterSystemUIBroadcastReceiver
07-21 13:40:37.171 6471 6471 D OplusScrollToTopManager: io.homeassistant.companion.android/io.homeassistant.companion.android.assist.AssistActivity, unregisterSystemUIBroadcastReceiver failed java.lang.IllegalArgumentException: Receiver not registered: android.view.OplusScrollToTopManager$2@3d95da6
07-21 13:40:37.175 6471 6471 D OpenGLRenderer: RenderProxy::destroy: this=0xb4000077b38ed800, mContext=0xb4000076db4a5b40
07-21 13:40:37.175 6471 11574 D OpenGLRenderer: SkiaOpenGLPipeline::setSurface: this=0xb40000772bbd6e00, surface=NULL
07-21 13:40:37.175 6471 11574 D BufferQueueProducer: [VRI[AssistActivity]#10(BLAST Consumer)10](id:19470000000a,api:1,p:6471,c:6471) disconnect: api 1
07-21 13:40:37.176 6471 11574 D BufferQueueConsumer: [VRI[AssistActivity]#10(BLAST Consumer)10](id:19470000000a,api:0,p:-1,c:6471) disconnect
07-21 13:40:39.404 6471 11544 D VRI[SettingsActivity]: dispatchAppVisibility visible:true
07-21 13:40:39.411 6471 6471 D VRI[SettingsActivity]: setWindowStopped stopped:false
07-21 13:40:39.417 6471 6471 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1689961206928, currentMillis: 1689961239416)
07-21 13:40:39.445 6471 6471 D BufferQueueConsumer: [](id:19470000000b,api:0,p:-1,c:6471) connect: controlledByApp=false
07-21 13:40:39.445 6471 6471 E IPCThreadState: attemptIncStrongHandle(88): Not supported
07-21 13:40:39.445 6471 11574 D BufferQueueProducer: [VRI[SettingsActivity]#11(BLAST Consumer)11](id:19470000000b,api:1,p:6471,c:6471) connect: api=1 producerControlledByApp=true
07-21 13:40:39.445 6471 6471 D VRI[SettingsActivity]: registerCallbacksForSync syncBuffer=false
07-21 13:40:39.489 6471 11574 D VRI[SettingsActivity]: Received frameCommittedCallback lastAttemptedDrawFrameNum=1 didProduceBuffer=true syncBuffer=false
07
