currently I am facing an issue which make it impossible to edit existing flow´s or create new ones.
The websocket connection to homeassisant doesn´t seem to be working, I assume, because on the call service node, the domains/services etc are not loaded:
And in the background this is happening (don´t know if it has to be like this):
The problem is, I don´t know when it stopped working - I´ll always try to keep everything updated and seem to have missed something.
Upon start of the Add-On, the log doesn´t seem to provide anything suspicous:
8 Nov 11:15:28 - [debug] red/nodes/flows.start : starting flow : 09ea1da58b76c19b
8 Nov 11:15:28 - [debug] red/nodes/flows.start : starting flow : 43a9260d5b033349
8 Nov 11:15:28 - [debug] red/nodes/flows.start : starting flow : e043d801b88fdaac
8 Nov 11:15:28 - [debug] red/nodes/flows.start : starting flow : 37ae1fbcc9c80610
8 Nov 11:15:28 - [debug] red/nodes/flows.start : starting flow : f39c4ace3960891e
8 Nov 11:15:28 - [debug] [server-state-changed:BWM Treppenhaus] instantiated node, name: BWM Treppenhaus
8 Nov 11:15:28 - [debug] [server-state-changed:BWM Diele] instantiated node, name: BWM Diele
8 Nov 11:15:28 - [debug] [api-current-state:531c4eb920d6b6a6] instantiated node, name:
8 Nov 11:15:28 - [debug] [api-current-state:ef5aeba045550551] instantiated node, name:
8 Nov 11:15:28 - [debug] [api-call-service:Licht Diele aus] instantiated node, name: Licht Diele aus
8 Nov 11:15:28 - [debug] [api-call-service:Licht Diele] instantiated node, name: Licht Diele
8 Nov 11:15:28 - [debug] [api-call-service:Rollladen EG hoch] instantiated node, name: Rollladen EG hoch
8 Nov 11:15:28 - [debug] [api-call-service:SChreibtisch an ] instantiated node, name: SChreibtisch an
8 Nov 11:15:28 - [debug] [api-call-service:a4aa215a2beae2a3] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-call-service:MorgenRoutine zurücksetzen] instantiated node, name: MorgenRoutine zurücksetzen
8 Nov 11:15:28 - [debug] [inject:4 Uhr morgens] crontab = 00 04 * * *
8 Nov 11:15:28 - [debug] [api-current-state:Morgen Routine ausgeführt?] instantiated node, name: Morgen Routine ausgeführt?
8 Nov 11:15:28 - [debug] [api-call-service:Spiele NJOY] instantiated node, name: Spiele NJOY
8 Nov 11:15:28 - [debug] [api-call-service:Morgen Routine true] instantiated node, name: Morgen Routine true
8 Nov 11:15:28 - [debug] [server-state-changed:Switch betätigt] instantiated node, name: Switch betätigt
8 Nov 11:15:28 - [debug] [api-call-service:Unterbauleuchten] instantiated node, name: Unterbauleuchten
8 Nov 11:15:28 - [debug] [api-call-service:255c69b6e6ee1858] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-call-service:7b45f84e4216490c] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-current-state:PV Batterie > 20%] instantiated node, name: PV Batterie > 20%
8 Nov 11:15:28 - [debug] [api-call-service:Heizung AN] instantiated node, name: Heizung AN
8 Nov 11:15:28 - [debug] [api-call-service:Heizung AUS] instantiated node, name: Heizung AUS
8 Nov 11:15:28 - [debug] [api-current-state:Heizung auf Auto] instantiated node, name: Heizung auf Auto
8 Nov 11:15:28 - [debug] [server-state-changed:Aktueller Bezug > 500] instantiated node, name: Aktueller Bezug > 500
8 Nov 11:15:28 - [debug] [poll-state:PV Leistung > 600] instantiated node, name: PV Leistung > 600
8 Nov 11:15:28 - [debug] [api-current-state:PC An ? ] instantiated node, name: PC An ?
8 Nov 11:15:28 - [debug] [server-state-changed:Aktueller Bezug < -300] instantiated node, name: Aktueller Bezug < -300
8 Nov 11:15:28 - [debug] [api-call-service:a041ebf088797b50] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [server-state-changed:579c66e38a2bdb50] instantiated node, name:
8 Nov 11:15:28 - [debug] [api-call-service:bebe0755b258c659] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [server-state-changed:Briefkasten Kontaktsensor] instantiated node, name: Briefkasten Kontaktsensor
8 Nov 11:15:28 - [debug] [api-call-service:b47d67a909c28461] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [server-state-changed:Rollladen OG ] instantiated node, name: Rollladen OG
8 Nov 11:15:28 - [debug] [api-call-service:Alle Lichter im OG aus] instantiated node, name: Alle Lichter im OG aus
8 Nov 11:15:28 - [debug] [api-current-state:Wenn die Sonne über dem Horizont steht] instantiated node, name: Wenn die Sonne über dem Horizont steht
8 Nov 11:15:28 - [debug] [api-call-service:123b87844a10ae58] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [server-state-changed:Briefkasten Tür geöffnet] instantiated node, name: Briefkasten Tür geöffnet
8 Nov 11:15:28 - [debug] [api-call-service:Anzeige zurücksetzen] instantiated node, name: Anzeige zurücksetzen
8 Nov 11:15:28 - [debug] [api-call-service:Lichter Flur/WZ aus] instantiated node, name: Lichter Flur/WZ aus
8 Nov 11:15:28 - [debug] [api-call-service:TV Stromlos] instantiated node, name: TV Stromlos
8 Nov 11:15:28 - [debug] [server-state-changed:Energieverbrauch des TVs <40W für 5 Minuten] instantiated node, name: Energieverbrauch des TVs <40W für 5 Minuten
8 Nov 11:15:28 - [debug] [api-call-service:Panel aus] instantiated node, name: Panel aus
8 Nov 11:15:28 - [debug] [inject:3ddd39216290ce77] crontab = 00 07 * * *
8 Nov 11:15:28 - [debug] [api-call-service:Wallpanel & Lichter an] instantiated node, name: Wallpanel & Lichter an
8 Nov 11:15:28 - [debug] [api-call-service:0f2f3cbacf6af928] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-call-service:Lichter Küche Aus] instantiated node, name: Lichter Küche Aus
8 Nov 11:15:28 - [debug] [flow:43a9260d5b033349] not starting disabled node : 5baca957548002f7
8 Nov 11:15:28 - [debug] [api-call-service:92a8edfa9ccf6bbb] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-current-state:02d99352c4e6ec0a] instantiated node, name:
8 Nov 11:15:28 - [debug] [api-call-service:13bf7600898b76ed] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-call-service:Zeige schlafsymbol auf der SmartClock] instantiated node, name: Zeige schlafsymbol auf der SmartClock
8 Nov 11:15:28 - [debug] [api-call-service:731594b27c2fb6df] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-call-service:SmartClock Display An] instantiated node, name: SmartClock Display An
8 Nov 11:15:28 - [debug] [server-state-changed:BWM im Treppenhaus] instantiated node, name: BWM im Treppenhaus
8 Nov 11:15:28 - [debug] [api-call-service:b7d01346b7673a5d] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-call-service:SleepDisplay entfernen] instantiated node, name: SleepDisplay entfernen
8 Nov 11:15:28 - [debug] [server-state-changed:ae909fbc4a3b4e4b] instantiated node, name:
8 Nov 11:15:28 - [debug] [api-call-service:becf1c543d63ee88] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-call-service:da9c743b6cde517c] instantiated node, name: undefined
8 Nov 11:15:28 - [debug] [api-current-state:9e71dcf909cc0647] instantiated node, name:
8 Nov 11:15:28 - [debug] [server-events:iOS Event received] instantiated node, name: iOS Event received
8 Nov 11:15:28 - [debug] [api-call-service:Verfügbar Schalten] instantiated node, name: Verfügbar Schalten
8 Nov 11:15:28 - [debug] [api-call-service:Ist Ok Schalten] instantiated node, name: Ist Ok Schalten
8 Nov 11:15:28 - [debug] [api-call-service:Nur wenn Wichtig Schalten] instantiated node, name: Nur wenn Wichtig Schalten
8 Nov 11:15:28 - [debug] [api-call-service:Nicht Stören Schalten] instantiated node, name: Nicht Stören Schalten
8 Nov 11:15:28 - [debug] [poll-state:7eb587801ab80496] instantiated node, name:
8 Nov 11:15:28 - [debug] [api-call-service:Screens Entfernen] instantiated node, name: Screens Entfernen
8 Nov 11:15:28 - [debug] [api-call-service:TEMPLATE zum kopieren] instantiated node, name: TEMPLATE zum kopieren
8 Nov 11:15:28 - [debug] [server-state-changed:Verfügbarkeitsstatus hat sich geändert] instantiated node, name: Verfügbarkeitsstatus hat sich geändert
8 Nov 11:15:28 - [debug] [api-call-service:Setze Screen] instantiated node, name: Setze Screen
8 Nov 11:15:28 - [debug] [poll-state:6d8b0568d3432705] instantiated node, name:
8 Nov 11:15:28 - [debug] [flow:f39c4ace3960891e] not starting disabled node : 52e1d33f19f33ab4
8 Nov 11:15:28 - [debug] [api-call-service:Setze Alert] instantiated node, name: Setze Alert
8 Nov 11:15:28 - [debug] [api-call-service:SingleMode Icon mit mit DisplayText] instantiated node, name: SingleMode Icon mit mit DisplayText
8 Nov 11:15:28 - [debug] [server-state-changed:cbfd37be60f9c752] instantiated node, name:
8 Nov 11:15:28 - [debug] [api-call-service:Zeige Solarbatterieladung an] instantiated node, name: Zeige Solarbatterieladung an
8 Nov 11:15:28 - [debug] [poll-state:Restmüll] instantiated node, name: Restmüll
8 Nov 11:15:28 - [debug] [api-call-service:Alerts verstecken] instantiated node, name: Alerts verstecken
8 Nov 11:15:28 - [debug] [inject:50b96aee7a7f2702] repeat = 60000
8 Nov 11:15:28 - [debug] [api-call-service:Uhrzeit anzeigen] instantiated node, name: Uhrzeit anzeigen
8 Nov 11:15:28 - [debug] [api-current-state:31c597735f154d53] instantiated node, name:
8 Nov 11:15:28 - [debug] [poll-state:Alpapier] instantiated node, name: Alpapier
8 Nov 11:15:28 - [debug] [poll-state:Gelber SAck] instantiated node, name: Gelber SAck
8 Nov 11:15:28 - [debug] [poll-state:c8b4417e94c04a9c] instantiated node, name:
8 Nov 11:15:28 - [debug] [poll-state:3ff132ca2261a7bf] instantiated node, name:
8 Nov 11:15:28 - [info] Started flows
[11:15:28] INFO: Starting NGinx...
8 Nov 11:15:33 - [info] [server:Home Assistant] Connecting to http://supervisor/core
8 Nov 11:15:33 - [info] [server:Home Assistant] Connected to http://supervisor/core
8 Nov 11:15:33 - [debug] [server:Home Assistant] States Loaded
8 Nov 11:15:33 - [debug] [server:Home Assistant] Integration: loaded
8 Nov 11:15:33 - [debug] [server:Home Assistant] Services Loaded
8 Nov 11:15:33 - [debug] [server:Home Assistant] HA State: running
Anyone got a suggestion where to look ?
