I am pretty sure I have everything set up correctly following this tutorial: Automation editor - Home Assistant and Script Syntax - Home Assistant
But still I cannot see a tab saying automation/script/configuration in the left side panel.
configuration.yaml
switch: !include switches.yaml
script: !include scripts.yaml
sensor: !include sensors.yaml
Filenames are corrrect since other automations which I put in automations.yaml (same directory as configuration.yaml) are loaded correctly. I gave every old (importoted from older config) automation an id. Example:
- id: test_aldshfsahd9fsaf
alias: 'Lamps on when at home'
platform: zone
entity_id: device_tracker.s6
zone: zone.home
event: enter
condition:
condition: sun
after: sunset
# Optional offset value
# after_offset: "-1:00:00"
service: mqtt.publish
topic: "switch/rf/2"
payload: "1|11111|11000"
For testing I made a backuo of automations.yaml and added an empty one. Still no side panel.
I even installed hass.io on my Rpi. There the side panel showed up correctly.
Any ideas?
Thank you.
edit
Solution
Add
config:
to the top level of your configuration.yaml and restart HA.
