No automations visible
Hii all,
I keep getting the following error. And now I cannot save any automations anymore.
All of them are gone. I had 8 of them.
This is what pops up in my notification:
Invalid config
The following integrations and platforms could not be set up:
It says:
Invalid config
Automation/ show logs
Default config/ show logs
Please check your config and logs
Did you do as suggested and check the config and logs?
Had similar in the past too, one of my automations was corrupt and that blocked it.
Hi Finity,
I looked at it but I am no expert.
What to do so that I can see the automatations. At the moment none visible in the UI.
Hi Vingerha,
In my case I have no more automations.
And when I make a new one then it just does not appear in the UI.
Click “show logs”. Paste content.
Hi Fleskefjes,
Here is the automatation logs
Here is the default_config logs
Show your configuration.yaml
Hi Francis,
Here is it:
Anything missing or wrong?
I believe the problem started after trying to install a blueprint.
I am not sure if others have a better proposal, here is mine:
  • copy automations.yaml to something else
If you know how to identify the error from automations.yaml…then you can correct it and restart
Else
  • delete automations.yaml, restart and see if fixed
    If fixed you can gradually add the automations from automations, yaml…highly likely the error is in one the last ones in the file OR one you updated recently
then remove the blueprint and its associated config.
also in the future you should post the actual text of any logs or code instead of screenshots.
Hi Vingerha,
I tried your solution and it worked.
I removed the contents of the automations.yaml after saving a copy somewhere else.
Then rebooted and the Invalid configuration errors dissapeared and the automation tab was visible again automation and scenes.
Then started adding the automations one by one and around line 102 things were good. After adding past line 102 then the same problem came back.
Many thanks for your solution!
I still have so much to learn.
Regards :grinning: :wave:
Hi Finity,
Thanks for your advise.
Blueprint is removed.
All working fine so far :-))
:wave:
