No cards available in dashboard edit
Hi All, im a captain so forgive me for not being very technical:
I am using a HA blue for 2 years now.
Some time ago i noticed that i can not add new cards to a dashboard.
I read an old reddit post stating that if i change the number formattig in my profile it may work, and it did!
But only untill after the next reload :frowning:
Does anyone have tips?
What i have tried:
i reloaded the browser, cleared it, used a different browser with zero history
I also removed all custom HACS stuff, rebooted numberous times, removed the Dash sources and tried again, then readded and tried again.
But i am stuck
In my browser console i keep getting this:
POLYFILL => User Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36, Browser: [object Object]
2content-scripts.js:1 INS: successfully injected instart
VM614 content-scripts.js:1 POLYFILL => User Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36, Browser: [object Object]
2VM614 content-scripts.js:1 INS: successfully injected instart
load_resource.ts:32
       GET https://changedthis./hacsfiles/vertical-stack-in-card/vertical-stack-in-card.js?hacstag=142051833050 net::ERR_ABORTED 404 (Not Found)
(anoniem) @ load_resource.ts:32
s @ load_resource.ts:6
i @ load_resource.ts:37
(anoniem) @ load-resources.ts:34
s @ load-resources.ts:13
(anoniem) @ ha-panel-lovelace.ts:252
Promise.then
value @ ha-panel-lovelace.ts:251
value @ ha-panel-lovelace.ts:166
performUpdate @ reactive-element.ts:1327
scheduleUpdate @ reactive-element.ts:1261
_$Ej @ reactive-element.ts:1233
await in _$Ej
requestUpdate @ reactive-element.ts:1208
_$Eu @ reactive-element.ts:946
w @ reactive-element.ts:931
C @ lit-element.ts:115
o @ ha-panel-lovelace.ts:51
k @ scoped-custom-element-registry.js:385
t @ scoped-custom-element-registry.js:236
value @ hass-router-page.ts:296
value @ hass-router-page.ts:316
(anoniem) @ hass-router-page.ts:214
Promise.then
value @ hass-router-page.ts:205
performUpdate @ reactive-element.ts:1329
await in _$Ej
set @ reactive-element.ts:726
j @ lit-html.ts:1883
_$AI @ lit-html.ts:1825
v @ lit-html.ts:1192
g @ lit-html.ts:1540
_$AI @ lit-html.ts:1384
q @ lit-html.ts:2183
update @ lit-element.ts:165
await in _$Ej
await in _$Ej
t @ home-assistant.ts:113
(anoniem) @ home-assistant.ts:123
n @ fire_event.ts:76
s @ navigate.ts:46
(anoniem) @ home-assistant.ts:136
load_resource.ts:32
       GET https://changedthis./hacsfiles/lovelace-xiaomi-vacuum-map-card/xiaomi-vacuum-map-card.js?hacstag=193372044224 net::ERR_ABORTED 404 (Not Found)
Promise.then
await in _$Ej
Promise.then
await in _$Ej
await in _$Ej
await in _$Ej
s @ navigate.ts:46
load_resource.ts:13 Uncaught (in promise) https://changedthis./hacsfiles/vertical-stack-in-card/vertical-stack-in-card.js?hacstag=142051833050
o.onerror @ load_resource.ts:13
error
(anoniem) @ load_resource.ts:13
Promise.then
await in _$Ej
Promise.then
await in _$Ej
await in _$Ej
await in _$Ej
s @ navigate.ts:46
load_resource.ts:13 Uncaught (in promise) https://changedthis/hacsfiles/lovelace-xiaomi-vacuum-map-card/xiaomi-vacuum-map-card.js?hacstag=193372044224
error
Promise.then
await in _$Ej
Promise.then
await in _$Ej
await in _$Ej
await in _$Ej
s @ navigate.ts:46
load_resource.ts:32
       GET https://changedthis./hacsfiles/energy-gauge-bundle-card/energy-gauge-bundle-card.js?hacstag=640516976003 net::ERR_ABORTED 404 (Not Found)
Promise.then
await in _$Ej
Promise.then
await in _$Ej
await in _$Ej
await in _$Ej
s @ navigate.ts:46
button-card.js?hacstag=146194325412:426   BUTTON-CARD   Version 4.1.2
load_resource.ts:13 Uncaught (in promise) https://changedthis.app/hacsfiles/energy-gauge-bundle-card/energy-gauge-bundle-card.js?hacstag=640516976003
error
Promise.then
await in _$Ej
Promise.then
await in _$Ej
await in _$Ej
await in _$Ej
s @ navigate.ts:46
mushroom.js?hacstag=444350375407:3423 πŸ„ Mushroom πŸ„ - 4.0.7
apexcharts-card.js?hacstag=331701152212:835  APEXCHARTS-CARD  v2.1.2
system logs says
Logger: aiohttp.server
Bron: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
Eerst voorgekomen: 23:36:24 (10 gebeurtenissen)
Laatst gelogd: 23:37:42
Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 77, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/image_upload/__init__.py", line 227, in get
    await hass.async_add_executor_job(
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/image_upload/__init__.py", line 251, in _generate_thumbnail_if_file_does_not_exist
    image = ImageOps.exif_transpose(Image.open(original_path))
  File "/usr/local/lib/python3.12/site-packages/PIL/Image.py", line 3431, in open
    fp = builtins.open(filename, "rb")
  File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
    return func(*args, **kwargs)
FileNotFoundError: [Errno 2] No such file or directory: '/config/image/9dcd406f5fcb82bbbad79a51964a2317/original'
I dont have a images folder in the config dir at all
ssh:
 ls
automations.yaml          home-assistant.log.fault  secrets.yaml
blueprints                home-assistant_v2.db      tts
config                    home-assistant_v2.db-shm  www
configuration.yaml        home-assistant_v2.db-wal  zigbee.db
custom_components         homeassistant             zigbee.db-shm
deps                      packages                  zigbee.db-wal
home-assistant.log        scenes.yaml
home-assistant.log.1      scripts.yaml
Via GUI filemanager i get acces denied for the config folder, /homeassistant is owned and run by root
i am on a Home assistant blue
Home Assistant
  • Core2024.10.2
  • Supervisor2024.10.2
  • Operating System13.2
  • Frontend20241002.3
ssh
 $ ps aux | grep homeassistant
root         333  0.0  0.0   8028  1920 ?        Ssl  Oct15   0:00 ttyd -d1 -i hassio --writable -p 64462 tmux -u new -A -s homeassistant zsh -l
martin      386  0.0  0.0   1704   768 pts/0    S+   00:08   0:00 grep homeassistant
ssh
\[\e]0;\u@\h:\w\a\]\W $ ls -l /homeassistant/www
total 4
drwxr-xr-x    9 root     root          4096 Oct 15 23:47 community
total 43156
-rw-r--r--    1 root     root          2867 Oct 15 19:40 automations.yaml
drwxr-xr-x    4 root     root          4096 Oct 13 23:16 blueprints
lrwxrwxrwx    1 root     root             7 Oct 14 13:23 config -> /config
-rwxr-xr-x    1 root     root           964 Oct 15 19:32 configuration.yaml
drwxr-xr-x    6 root     root          4096 Oct 15 23:22 custom_components
drwxr-xr-x    2 root     root          4096 Oct 13 23:16 deps
-rw-r--r--    1 root     root         39336 Oct 16 00:07 home-assistant.log
-rw-r--r--    1 root     root         21963 Oct 15 23:26 home-assistant.log.1
-rw-r--r--    1 root     root             0 Oct 15 23:28 home-assistant.log.fault
-rwxr-xr-x    1 root     root      39067648 Oct 16 00:07 home-assistant_v2.db
-rwxr-xr-x    1 root     root         32768 Oct 16 00:09 home-assistant_v2.db-shm
-rwxr-xr-x    1 root     root       4791592 Oct 16 00:09 home-assistant_v2.db-wal
lrwxrwxrwx    1 root     root            14 Oct 14 13:23 homeassistant -> /homeassistant
drwxr-xr-x    2 root     root          4096 Oct 15 16:31 packages
-rwxr-xr-x    1 root     root             0 Oct 13 23:16 scenes.yaml
-rwxr-xr-x    1 root     root             0 Oct 13 23:16 scripts.yaml
-rwxr-xr-x    1 root     root           161 Oct 13 23:16 secrets.yaml
drwxr-xr-x    2 root     root          4096 Oct 15 17:41 tts
drwxr-xr-x    3 root     root          4096 Oct 14 17:02 www
-rwxr-xr-x    1 root     root        110592 Oct 15 23:26 zigbee.db
-rwxr-xr-x    1 root     root         32768 Oct 15 23:54 zigbee.db-shm
-rwxr-xr-x    1 root     root         32992 Oct 15 23:54 zigbee.db-wal
Bumped
Are you trying to add a new card by pressing a topmost β€œ(+)” button, not an β€œAdd card” button?
yes! and the blue button seems to work indeed
i feel so stupid now )) But thanks
