No CarPlay iOS 18
Hi, there,
Since a few days I don’t have assistant in CarPlay it has completely disappeared I am in iOS 18 at first it worked and since a few days I don’t have access to CarPlay assistant and I can’t add it it has disappeared. Do you know where this is coming from?
Thank you if you have the solution if you have already had this problem. Thanks
i have exactly the same issue and don‘t know how to fix it
ok, i could fix it by deleting the app, reboot and install again…
