i installed the emulated_hue add on after this, and here is that log:
2021-01-01 16:46:26,216 DEBUG emulated_hue.utils β Loading /data/emulated_hue.json failed: [Errno 2] No such file or directory: β/data/emulated_hue.jsonβ
2021-01-01 16:46:26,218 INFO emulated_hue.config β Auto detected listen IP address is 172.20.60.50
2021-01-01 16:46:26,259 DEBUG getmac β Raw MAC found: None
2021-01-01 16:46:26,262 DEBUG getmac β Raw MAC found: dc:a6:32:d4:28:b6
2021-01-01 16:46:26,263 DEBUG aiorun β Entering run()
2021-01-01 16:46:26,278 DEBUG aiorun β Creating default executor
2021-01-01 16:46:26,331 INFO hass-client β Connecting to hassio/homeassistant
2021-01-01 16:46:26,341 INFO emulated_hue.api β Started HTTP webserver on port 80
2021-01-01 16:46:26,353 INFO emulated_hue.api β Started HTTPS webserver on port 443
2021-01-01 16:46:26,377 DEBUG emulated_hue β Starting mDNS/uPNP discovery broadcastβ¦
Exception in thread Thread-3:
File β/usr/local/lib/python3.8/threading.pyβ, line 932, in _bootstrap_inner
self.run()
File β/app/emulated_hue/upnp.pyβ, line 64, in run
ssdp_socket.bind(("", 1900))
OSError: [Errno 98] Address already in use
2021-01-01 16:46:26,415 INFO hass-client β Connected to hassio/homeassistant
2021-01-01 16:46:26,460 DEBUG hass-client β Received area registry.
2021-01-01 16:46:26,460 DEBUG hass-client β Received device registry.
2021-01-01 16:46:26,464 DEBUG hass-client β Received entity registry.
2021-01-01 16:46:46,389 INFO hass-client β Connecting to hassio/homeassistant
