Hello dear community… I’ve been looking at a problem with my system for the last two days and I just can’t explain it… maybe you have an idea or know the problem?
I’ve had Homeassistant and zigbee running for a relatively long time (more than 2 years). My IKEA lamps, such as “TRADFRI bulb E14 CWS opal 600lm” and several “IKEA STYRBAR” (RemoteControl N2) have worked for a long time without any problems… I have always connected the lamps directly via the RemoteControl → lamp link so that this also works when HA is not online.
I was always able to switch the lamps on and off and dim them using the On/Off button. The left/right buttons always switched through the colors. This has now suddenly disappeared!
I have re-learned, reconnected and reconfigured the remote controls and lamps several times. But the “out-of-the-box” color switching function no longer works. I can only switch the lamps on and off and dim them using the remote control. In HA itself, everything continues to work without any problems. As I said, I don’t want to use blueprints or similar for this, as it should also work without Home Assistant!
Could it be that the ZHA components have received a firmware update that explains this change in behavior?
Do you have some hints? Thanks alot!
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.1.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "6.1.70-haos",
"supervisor": "2023.12.0",
"host_os": "Home Assistant OS 11.3",
"docker_version": "24.0.7",
"chassis": "embedded",
"run_as_root": true
"data": {
"ieee": "**REDACTED**",
"nwk": 56276,
"manufacturer": "IKEA of Sweden",
"model": "Remote Control N2",
"name": "IKEA of Sweden Remote Control N2",
"quirk_applied": true,
"quirk_class": "zhaquirks.ikea.fourbtnremote.IkeaTradfriRemoteV2",
"quirk_id": null,
"manufacturer_code": 4476,
"power_source": "Battery or Unknown",
"lqi": 124,
"rssi": -69,
"last_seen": "2024-01-07T15:56:39",
"available": true,
"device_type": "EndDevice",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4476, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0820",
"input_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0020",
"0x1000",
"0xfc57",
"0xfc7c"
"output_clusters": [
"0x0003",
"0x0005",
"0x0006",
"0x0008",
"0x0019",
"0x1000"
"active_coordinator": false,
"entities": [
"entity_id": "sensor.rc2_neu_batterie",
"entity_id": "button.rc2_neu_identifizieren",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "NON_COLOR_CONTROLLER"
"user_given_name": "RC2-neu",
"device_reg_id": "cfa6ab2581c480029035ce07195c1066",
"area_id": "arbeitsecke",
"cluster_details": {
"1": {
"device_type": {
"name": "NON_COLOR_CONTROLLER",
"id": 2080
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {},
"unsupported_attributes": {}
"0x0001": {
"endpoint_attribute": "power",
"attributes": {
"0x0021": {
"attribute_name": "battery_percentage_remaining",
"value": 255
"0x0020": {
"attribute_name": "battery_voltage",
"value": 29
"0x0031": {
"attribute_name": "battery_size"
"0x0033": {
"attribute_name": "battery_quantity"
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0020": {
"endpoint_attribute": "poll_control",
"attributes": {
"0x0000": {
"attribute_name": "checkin_interval",
"value": 13200
"0x1000": {
"endpoint_attribute": "lightlink",
"attributes": {},
"0xfc57": {
"endpoint_attribute": "manufacturer_specific",
"attributes": {},
"0xfc7c": {
"attributes": {},
"out_clusters": {
"0x0003": {
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {},
"0x0008": {
"endpoint_attribute": "level",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"0x1000": {
"attributes": {},
