Hi everyone,
I’m quite new to home assistant and everythings works perfectly. But sometimes when I need to restart the system for installing an addon or something else, I cannot connect to my server. I had the several times, but every 2-3 weeks I’m facing this problem. Most times I need to flash the SD card and install everything new and restore my backup. But this is exausting and frustrating.
Does anyone know a solution or is facing/had the same problem.
Actually I’m using the power supply that came with the pi and I only attached a zigbee dongle. The weird thing about this issue is, that the restart most of the is working without any problems. But sometimes when I restart the system from the UI, after checking the configuration, it seems to have a problem. In my router settings I can see the server connected with ethernet. When I flash the SD card and restore the backup from last night e.g. its working again without any problems.
