No cover mode for Shelly Plus 2PM
Hi ,
I am using 5 Shelly 2.5 to handle all my roller shutter,
now I changed one to Shelly Plus 2PM.
I installed it in Shelly app as cover and it is also recognized
by HA but there is no cover mode for Shelly 2PM available,
I am using the official Shells integration,
somebody an idea what I can do
Thank you
I am not using the Shelly app, so don’t know about those possibilities, but when I log in on the local Shelly Plus 2PM web interface there is an Cover option available under: Settings → Device settings → Device profile
Shelly2PM-2
This is with the current Shelly firmware version 1.0.3
Yes I use the Cover Mode for the Shelly Plus 2PM in the Shelly
App but I can not use it in HA because it is not available!?
I can online select it as switch in HA , but why?
its a known issue, created a bug report for it a long time ago:
Shelly Cover Issue
Topic starter refers to the official Shelly integration.
Personally I have no experience with the Cover mode, but as I understand it Home Assistant should support and automatically recognize the Plus 2PM Cover mode when using the official Shelly Integration.
Are you sure you selected the correct input button / switch mode?
One more thing to try if you didn’t do this yet after changing Shelly settings: restart Home Assistant, as that might cause the modified Shelly options to be recognized.
This bug report is about the ShellyForHASS integration, isn’t it?
The OP is using the official Shelly integration.
Ah yes you are right, I will delete the post.
I faced the same issue
Did it work with someone?
I also have this issue and it looks like there is no update on this yet
Bought 19 Shelly 2PM and also getting this issue on 2 of them :confused:
Edit: Just saw that the entity wast not updated
Try to go to devices, search for it and check if you have the button to add it to dashboard. From dashboard you can then check the enitty ID
no cover mode for shellyplus2pm
Were you able to get cover mode visible in hass ?
Here is my Solution:
ATTENTION: all entities change the Name!!!
Delete shellyforhass Integration in Hacs!
restart HA!
go to the Integration and download the offical Integration for shelly
Now your HA find your Shellys in the local Network! (also the cover mode for shelly 2pm)
After that you have to change all the entities for the shellys
after that is works fine!
I am a German Guy…Sorry for my bad English :slight_smile:
Not working for me :confused:
Hat bei mir nichts gebracht, der Shelly Plus 2PM zeigt immer noch 2 Schalter an obwohl im Shelly als Cover hinterlegt. Firmware 0.14 - 1.0.8 - 1.1.0 Beta2 alles probiert, ändert nichts.
Hast du im Webinterface (unter IP Adresse des Shelly) den Mode auf COVER gesetzt?
dein Shelly sollte so als entität sein: “cover.shellyplus2pm_fcb467bbxxxx”
Wenn du in der shelly APP die Cover Funktion einstellst, kann es passieren das dies nicht ĂĽbernommen wird! Deswegen ĂĽber das Webinterface am PC/Smartphone
Not sure if can help but try to calibrate the device first on Shelly app.
Try to calibrate your device first on Shelly app. After that “cover” mode appears on my HA after did the above step.
Habe das Problem lösen können… so wie es aussieht habe ich noch die Shelly APP aus HACS genutzt anstatt die von HA direkt. Nach dem Löschen der HACS Version welche ja nicht mehr entwickelt wird, ging es dann schließlich.
Die Shellys werden wohl von der “alten” HACS Version nicht unterstützt.
War zwar etwas arbeit alles wieder einzurichten aber letztenendlich habe ich es nun hinter mich gebracht ^^
LG und Danke!
Bei mir war das Problem, dass die Shellys nicht alle kalibriert waren.
Kalibieren und HA reboot hat geholfen, übrigens auch für Alexa, die hatte auch gezickt bei den Rolläden.
I have the same problem. I have a shelly plus 2PM connected to a blind and configured as cover in device profile . I have tried to do the integration with Home Assistant and I only have the shelly smart home for such integration. I have 2 devices (for two blinds that I have) and I can NOT do anything with them.
Somebody can help me please?
Regards and thank you
