Hi all,
I have a problem with my system. I´m usind HAOS with RaspberryMatic integration to work with my HmIP-STH temperature and humidity sensors. All is running very stable, I get the sensor values inside home assistant and can control temperature setpoint out of home assistant.
Now I want to log my data in InfluxDB and visualise it with Grafana. I installed both and also this is running good. All or at least most of my produced data is logged in InfluxDB except for my HmIP-STH sensors.
I tried some different configurations for InfluxDB but had no success.
Here is my configuration.yaml for influxDB:
influxdb:
username: xxx
password: xxx
tags:
source: HA
tags_attributes:
- friendly_name
default_measurement: state
exclude:
entities:
- zone.home
domains:
- persistent_notification
- person
include:
domains:
- sensor
- binary_sensor
- sun
- light
- cover
- weather
- climate
entities:
- climate.tempkz_thomas
- climate.tempkuche
- climate.tempwzimmer
- climate.tempbad
- climate.tempschlafzimmer
- climate.tempflur
- climate.tempeingang
- climate.tempkz_david
- climate.tempgastebad
Do you have any idea?
Addendum
I tried it also with a minmal influxdb config without success:
influxdb:
username: xxx
password: xxx
tags:
source: HA
tags_attributes:
- friendly_name
Abbendum
I think I have an approach through the video home assistant template sensors and auxiliary entities (helpers) 101 (German video).
I think I have to create templates to extract the attributes from the entities. At first this seems like a workaround to me. If it works I will post it here. If someone knows, I would be interested if this is really the way to do it, or just a workaround
Solution
So I have now as mentioned above in the addendum, for each attribute of the HmIP-STH created a “helper”. I did that first in the yaml, but then I noticed that they don’t show up in the UI under “Helpers” and so I had to do it again in the UI.
“Helper” → “Template” → “Create template for a sensor” → configure
created. Is a lot of work, but now I have data in influxDB and can evaluate them with Grafana.
What do you think about the “solution”. Is this the right way in HA or are there others?
I use the german language in HA, so the mentioned UI descriptions could be different in your UI.
