My haaska test was successful but when discovering devices I could not see any of my home assistant devices come up.
Hi there
I have the same problem?
Have you managed to make Haaska + Alexa work?
Thanks!
I have the same problem. I did a quite a lot of search, but didn’t find the answer. for example, I did enabled the trigger…
I am in a similar situation. Testing works fine, but Alexa App can not discover any new devices
As many guys answered, most probably, it’s because the region/country setup is problmatic
Anyone get this working, I have set up everything correctly as the test code returns endpointId info and I can see the device list even though Alexa told me it could not discover and devices but every entry is coming up as unresponsive.
I’m do believe that I have set up my regions correctly.
Matt
Guys, after a lot of dig, I’ve found that setting up a totally different region solved this for me. I’m in Europe so logically I choose Ireland and I had the same issue: Testing retrieves fine, but no devices after Discovery in the App. So I set to N.Virginia us-east-1 and discovery returned everything on first attempt.
Hope it helps
Thank you very much @xbyt That’s the solution for this problem in my case.
In order for Alexa Skill to properly work, the lambda MUST be (at least) in us-east-1.
