No devices found on zigbee2mqqt / mosquitto / conbee 2
I try to install my zigbee devices, but i don’t find any device in zigbee2mqqt add-on.
The installation seems to be ok, no errors in log of zigbee2mqqt or mosquitto…
What could be wrong in the installation?
Thanks.
Stupid question, but are your devices paired and visible in zigbee2mqtt?
I can’t find any device to pair
What devices are you trying to pair?
Most of the time, there is specific manipulation to do to put them in pairing mode.
Then you have to tell Z2M to find them (IDK how it actually works on Z2M, using ZHA myself).
Settings → Main → Permit join
I have teste seheral devices, ikea, aqara and xiaomi. Nothing appears on the mosquitto broker for as far as i see… I have Just watched à video and the devices are visible on the integration screen in the mosquitto broker. In my case nothing appears over there.
If you did not see error, the connection between zigbee2mqtt and mosquitto must be OK. You don’t see anything in the zigbee2mqtt log while pairing ? The log in the zigbee2mqtt frontend.
Did you install the mqtt integration ?
I did install the mosquitto mqtt
Do i have to install also an other mqtt intégration ?
Yes you do.
configuration → integrations → + add integration
Mosquitto is the broker, the mqtt integration is the integration that connects to your broker.
