No dimming functionality Qubino Dimmer
Yesterday i have added a new Qubino mini dimmer to my system, i have added it via a non-secure way because of an issue with the device becoming unresponsive after several days.
So far so good, but i’m missing the dimming functionality in Home Assistant. Other devices work without a problem.
Screen Shot 2022-10-31 at 15.56.43
vs
Screen Shot 2022-10-31 at 15.57.04
Things i have tried so far,
  • Re-interview
  • Removing and adding from the Z-wave Network
  • Factory reset of the device
I have looked at the debug log but i’m not getting any obvious errors.
Can anyone point me in the right direction for troubleshooting this
Below i have added the diagnostics (edited because of length) of the device.
    "entities": [
        "domain": "switch",
        "entity_id": "switch.mini_dimmer_2",
        "original_name": "",
        "original_device_class": null,
        "disabled": false,
        "disabled_by": null,
        "hidden_by": null,
        "original_icon": null,
        "entity_category": null,
        "supported_features": 0,
        "unit_of_measurement": null,
        "value_id": "19-37-0-currentValue",
        "primary_value": {
          "command_class": 37,
          "command_class_name": "Binary Switch",
          "endpoint": 0,
          "property": "currentValue",
          "property_name": "currentValue",
          "property_key": null,
          "property_key_name": null
        "domain": "sensor",
        "entity_id": "sensor.mini_dimmer_electric_consumption_kwh_2",
        "original_name": "Electric Consumption [kWh]",
        "original_device_class": "energy",
        "disabled": false,
        "hidden_by": null,
        "unit_of_measurement": "kWh",
        "value_id": "19-50-0-value-65537",
        "primary_value": {
          "command_class": 50,
          "command_class_name": "Meter",
          "endpoint": 0,
          "property": "value",
          "property_name": "value",
          "property_key": 65537,
          "property_key_name": "Electric_kWh_Consumed"
        "domain": "sensor",
        "entity_id": "sensor.mini_dimmer_electric_consumption_w_2",
        "original_name": "Electric Consumption [W]",
        "original_device_class": "power",
        "disabled": false,
        "hidden_by": null,
        "unit_of_measurement": "W",
        "value_id": "19-50-0-value-66049",
        "primary_value": {
          "endpoint": 0,
          "property_key": 66049,
          "property_key_name": "Electric_W_Consumed"
        "domain": "binary_sensor",
        "entity_id": "binary_sensor.mini_dimmer_over_load_detected",
        "original_name": "Over-load detected",
        "original_device_class": "safety",
        "disabled": false,
        "hidden_by": null,
        "entity_category": "diagnostic",
        "value_id": "19-113-0-Power Management-Over-load status",
        "primary_value": null
        "domain": "sensor",
        "entity_id": "sensor.mini_dimmer_over_load_status",
        "original_name": "Over-load status",
        "disabled": true,
        "disabled_by": "integration",
        "hidden_by": null,
        "domain": "sensor",
        "entity_id": "sensor.mini_dimmer_alarm_type",
        "original_name": "Alarm Type",
        "disabled": true,
        "hidden_by": null,
        "value_id": "19-113-0-alarmType",
        "primary_value": {
          "command_class": 113,
          "command_class_name": "Notification",
          "endpoint": 0,
          "property": "alarmType",
          "property_name": "alarmType",
        "domain": "sensor",
        "entity_id": "sensor.mini_dimmer_alarm_level",
        "original_name": "Alarm Level",
        "disabled": true,
        "hidden_by": null,
        "value_id": "19-113-0-alarmLevel",
        "primary_value": {
          "endpoint": 0,
          "property": "alarmLevel",
          "property_name": "alarmLevel",
    "state": {
      "nodeId": 19,
      "index": 0,
      "installerIcon": 7424,
      "userIcon": 7424,
      "status": 4,
      "ready": true,
      "isListening": true,
      "isRouting": true,
      "isSecure": false,
      "manufacturerId": 345,
      "productId": 85,
      "productType": 1,
      "firmwareVersion": "20.0",
      "zwavePlusVersion": 1,
      "deviceConfig": {
        "filename": "/data/db/devices/0x0159/zmnhhd.json",
        "isEmbedded": true,
        "manufacturer": "Qubino",
        "label": "ZMNHHD",
        "description": "Mini Dimmer",
        "devices": [
            "productType": 1,
            "productId": 85
        "firmwareVersion": {
          "min": "0.0",
          "max": "255.255"
        "associations": {},
        "paramInformation": {
          "_map": {}
        "metadata": {
      "label": "ZMNHHD",
      "interviewAttempts": 1,
      "endpoints": [
          "nodeId": 19,
          "index": 0,
          "userIcon": 7424,
          "deviceClass": {
            "basic": {
              "key": 4,
              "label": "Routing Slave"
            "generic": {
              "key": 16,
              "label": "Binary Switch"
            "specific": {
              "key": 1,
              "label": "Binary Power Switch"
            "mandatorySupportedCCs": [
              32,
              37,
              39
            "mandatoryControlledCCs": []
          "commandClasses": [
              "id": 37,
              "name": "Binary Switch",
              "version": 1,
              "isSecure": false
              "id": 94,
              "name": "Z-Wave Plus Info",
              "version": 2,
              "isSecure": false
              "id": 133,
              "name": "Association",
              "version": 2,
              "isSecure": false
              "id": 89,
              "name": "Association Group Information",
              "version": 2,
              "isSecure": false
              "id": 85,
              "name": "Transport Service",
              "version": 2,
              "isSecure": false
              "id": 134,
              "name": "Version",
              "version": 2,
              "isSecure": false
              "id": 114,
              "name": "Manufacturer Specific",
              "version": 2,
              "isSecure": false
              "id": 90,
              "name": "Device Reset Locally",
              "version": 1,
              "isSecure": false
              "id": 112,
              "name": "Configuration",
              "version": 1,
              "isSecure": false
              "id": 50,
              "name": "Meter",
              "version": 4,
              "isSecure": false
              "id": 113,
              "name": "Notification",
              "version": 8,
              "isSecure": false
              "id": 115,
              "name": "Powerlevel",
              "version": 1,
              "isSecure": false
              "id": 152,
              "name": "Security",
              "version": 1,
              "isSecure": true
              "id": 159,
              "name": "Security 2",
              "version": 1,
              "isSecure": true
              "id": 108,
              "name": "Supervision",
              "version": 1,
              "isSecure": false
      "values": [
          "endpoint": 0,
          "commandClass": 37,
          "commandClassName": "Binary Switch",
          "propertyName": "currentValue",
          "ccVersion": 1,
          "metadata": {
            "type": "boolean",
            "readable": true,
            "writeable": false,
            "label": "Current value"
          "value": false
          "endpoint": 0,
          "commandClass": 37,
          "property": "targetValue",
          "propertyName": "targetValue",
          "ccVersion": 1,
          "metadata": {
            "type": "boolean",
            "readable": true,
            "writeable": true,
            "label": "Target value",
            "valueChangeOptions": [
              "transitionDuration"
          "value": false
          "endpoint": 0,
          "commandClass": 50,
          "commandClassName": "Meter",
          "property": "reset",
          "propertyName": "reset",
          "ccVersion": 4,
          "metadata": {
            "type": "boolean",
            "readable": false,
            "writeable": true,
            "label": "Reset accumulated values"
          "endpoint": 0,
          "commandClass": 112,
          "commandClassName": "Configuration",
          "property": 1,
          "propertyName": "In-wall Switch Type for Load to Control I1",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "In-wall Switch Type for Load to Control I1",
            "default": 0,
            "min": 0,
            "max": 1,
            "states": {
              "0": "Momentary",
              "1": "Toggle"
            "valueSize": 1,
            "format": 1,
            "allowManualEntry": false,
            "isFromConfig": true
          "value": 0
          "endpoint": 0,
          "property": 11,
          "propertyName": "Turn Load 1 Off Automatically With Timer",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Turn Load 1 Off Automatically With Timer",
            "default": 0,
            "min": 0,
            "max": 32536,
            "states": {
              "0": "Disable"
            "unit": "seconds",
            "valueSize": 2,
            "format": 1,
            "allowManualEntry": true,
          "value": 0
          "endpoint": 0,
          "property": 12,
          "propertyName": "Turn Load 1 On Automatically With Timer",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Turn Load 1 On Automatically With Timer",
            "default": 0,
            "min": 0,
            "max": 32536,
            "states": {
              "0": "Disabled"
            "unit": "seconds",
            "valueSize": 2,
            "format": 1,
          "value": 0
          "endpoint": 0,
          "property": 21,
          "propertyName": "Double Click Function",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Double Click Function",
            "default": 0,
            "min": 0,
            "max": 1,
            "states": {
              "0": "Disable",
              "1": "Enable"
            "valueSize": 1,
            "format": 1,
          "value": 0
          "endpoint": 0,
          "property": 30,
          "propertyName": "State After Power Failure",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "State After Power Failure",
            "default": 0,
            "min": 0,
            "max": 1,
            "states": {
              "0": "Previous state",
              "1": "Always off"
            "valueSize": 1,
            "format": 0,
          "value": 0
          "endpoint": 0,
          "property": 40,
          "propertyName": "Power Change Reporting Threshold For Load",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Power Change Reporting Threshold For Load",
            "default": 10,
            "min": 0,
            "max": 100,
            "states": {
              "0": "Disable"
            "unit": "%",
            "valueSize": 1,
            "format": 1,
          "value": 10
          "endpoint": 0,
          "property": 42,
          "propertyName": "Power Reporting Interval",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Power Reporting Interval",
            "default": 0,
            "min": 0,
            "max": 32767,
            "states": {
              "0": "Disable"
            "unit": "seconds",
            "valueSize": 2,
            "format": 1,
          "value": 0
          "endpoint": 0,
          "property": 61,
          "propertyName": "Maximum Dimming Level",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Maximum Dimming Level",
            "default": 99,
            "min": 2,
            "max": 99,
            "valueSize": 1,
            "format": 1,
          "value": 99
          "endpoint": 0,
          "property": 65,
          "propertyName": "Dimming Duration (Key Pressed)",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Dimming Duration (Key Pressed)",
            "default": 1,
            "min": 1,
            "max": 127,
            "unit": "seconds",
            "valueSize": 1,
            "format": 1,
          "value": 1
          "endpoint": 0,
          "property": 66,
          "propertyName": "Dimming Duration (Key Held)",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "description": "1-127 seconds; 128-253 minutes (minus 127)",
            "label": "Dimming Duration (Key Held)",
            "default": 3,
            "min": 1,
            "max": 253,
            "valueSize": 2,
            "format": 1,
          "value": 3
          "endpoint": 0,
          "property": 67,
          "propertyName": "Ignore Pre-Set Dimming Start Level",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Ignore Pre-Set Dimming Start Level",
            "default": 0,
            "min": 0,
            "max": 1,
            "states": {
              "0": "Disable",
              "1": "Enable"
            "valueSize": 1,
            "format": 1,
          "value": 0
          "endpoint": 0,
          "property": 68,
          "propertyName": "Dimming Duration",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "description": "In switch mode the parameter has no effect",
            "label": "Dimming Duration",
            "default": 0,
            "min": 0,
            "max": 127,
            "states": {
              "0": "Dimming duration according to Dimming Duration (Key Held)"
            "unit": "seconds",
            "valueSize": 1,
            "format": 1,
          "value": 0
          "endpoint": 0,
          "property": 70,
          "propertyName": "Overload Protection",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Overload Protection",
            "default": 200,
            "min": 0,
            "max": 200,
            "states": {
              "0": "Disable"
            "unit": "W",
            "valueSize": 2,
            "format": 1,
          "value": 200
          "endpoint": 0,
          "property": 71,
          "propertyName": "Calibration Trigger",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Calibration Trigger",
            "default": 0,
            "min": 0,
            "max": 2,
            "states": {
              "0": "After exclusion",
              "1": "After power cycle",
              "2": "Force calibration"
            "valueSize": 1,
            "format": 1,
          "value": 1
          "endpoint": 0,
          "property": 72,
          "propertyName": "Calibration Status",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Calibration Status",
            "default": 2,
            "min": 1,
            "max": 2,
            "states": {
              "1": "Successful",
              "2": "Failed"
            "valueSize": 1,
            "format": 1,
          "value": 1
          "endpoint": 0,
          "property": 73,
          "propertyName": "Action on Alarm/Notification Events",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Action on Alarm/Notification Events",
            "default": 0,
            "min": 1,
            "max": 3,
            "states": {
              "1": "Turn off",
              "2": "Turn on",
              "3": "Blink load"
            "valueSize": 1,
            "format": 1,
          "value": 0
          "endpoint": 0,
          "property": 74,
          "propertyName": "Alarm/Notification Action Duration",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Alarm/Notification Action Duration",
            "default": 10,
            "min": 1,
            "max": 125,
            "unit": "minutes",
            "valueSize": 1,
            "format": 1,
          "value": 10
          "endpoint": 0,
          "property": 5,
          "propertyName": "Working mode",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Working mode",
            "default": 0,
            "min": 0,
            "max": 1,
            "states": {
              "0": "Dimmer mode",
              "1": "Switch mode"
            "valueSize": 1,
            "format": 0,
          "value": 0
          "endpoint": 0,
          "property": 6,
          "propertyName": "Load Type",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Load Type",
            "default": 0,
            "min": 0,
            "max": 1,
            "states": {
              "0": "Dimmable load",
              "1": "Non-dimmable load"
            "valueSize": 1,
            "format": 1,
          "endpoint": 0,
          "property": 60,
          "propertyName": "Minimum Dimming Level",
          "ccVersion": 1,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": true,
            "label": "Minimum Dimming Level",
            "default": 0,
            "min": 0,
            "max": 98,
            "valueSize": 1,
            "format": 1,
          "endpoint": 0,
          "commandClass": 113,
          "commandClassName": "Notification",
          "propertyName": "alarmType",
          "ccVersion": 0,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Alarm Type",
            "min": 0,
            "max": 255
          "endpoint": 0,
          "propertyName": "alarmLevel",
          "ccVersion": 0,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Alarm Level",
            "min": 0,
            "max": 255
          "endpoint": 0,
          "commandClass": 114,
          "commandClassName": "Manufacturer Specific",
          "property": "manufacturerId",
          "propertyName": "manufacturerId",
          "ccVersion": 2,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Manufacturer ID",
            "min": 0,
            "max": 65535
          "value": 345
          "endpoint": 0,
          "property": "productType",
          "propertyName": "productType",
          "ccVersion": 2,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Product type",
            "min": 0,
            "max": 65535
          "value": 1
          "endpoint": 0,
          "property": "productId",
          "propertyName": "productId",
          "ccVersion": 2,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Product ID",
            "min": 0,
            "max": 65535
          "value": 85
          "endpoint": 0,
          "commandClass": 134,
          "commandClassName": "Version",
          "property": "libraryType",
          "propertyName": "libraryType",
          "ccVersion": 2,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Library type",
            "states": {
              "0": "Unknown",
              "1": "Static Controller",
              "2": "Controller",
              "3": "Enhanced Slave",
              "4": "Slave",
              "5": "Installer",
              "6": "Routing Slave",
              "7": "Bridge Controller",
              "8": "Device under Test",
              "9": "N/A",
              "10": "AV Remote",
              "11": "AV Device"
          "value": 3
          "endpoint": 0,
          "property": "protocolVersion",
          "propertyName": "protocolVersion",
          "ccVersion": 2,
          "metadata": {
            "type": "string",
            "readable": true,
            "writeable": false,
            "label": "Z-Wave protocol version"
          "value": "5.3"
          "endpoint": 0,
          "property": "firmwareVersions",
          "propertyName": "firmwareVersions",
          "ccVersion": 2,
          "metadata": {
            "type": "string[]",
            "readable": true,
            "writeable": false,
            "label": "Z-Wave chip firmware versions"
          "value": [
            "20.0",
            "20.0"
          "endpoint": 0,
          "property": "hardwareVersion",
          "propertyName": "hardwareVersion",
          "ccVersion": 2,
          "metadata": {
            "type": "number",
            "readable": true,
            "writeable": false,
            "label": "Z-Wave chip hardware version"
          "value": 2
      "isFrequentListening": false,
      "maxDataRate": 100000,
      "supportedDataRates": [
        40000,
        100000
      "protocolVersion": 3,
      "supportsBeaming": true,
      "supportsSecurity": false,
      "nodeType": 1,
      "zwavePlusNodeType": 0,
      "zwavePlusRoleType": 5,
      "deviceClass": {
        "basic": {
          "key": 4,
        "generic": {
          "key": 16,
        "specific": {
          "key": 1,
          32,
          37,
          39
      "interviewStage": "Complete",
      "deviceDatabaseUrl": "https://devices.zwave-js.io/?jumpTo=0x0159:0x0001:0x0055:20.0",
      "statistics": {
        "commandsTX": 166,
        "commandsRX": 184,
        "commandsDroppedRX": 0,
        "commandsDroppedTX": 0,
        "timeoutResponse": 12,
        "rtt": 250.5
      "highestSecurityClass": -1,
      "isControllerNode": false,
      "keepAwake": false
Try a re-interview, and post the driver debug logs of the process.
Hi Freshcoast,
Thanks for your reply, but unfortunately i have already tried this with no result.
Edit: Sorry reading… Will try a re-interview with debug log on.
The logs would confirm whether there was a problem during the interview. Without logs, it’s difficult to help you. You have several timeouts shown in the statistics.
Sorry, my fault. I edited my post, thought I was fast enough but apparently not. :stuck_out_tongue:
I have used Pastebin for posting the debug log as there are to many characters for posting the full debug log.
Debug Log
It ends with, this looks like a succes to me.
2022-10-31T16:12:39.768Z CNTRLR   [Node 019] Interview stage completed: CommandClasses
2022-10-31T16:12:39.768Z CNTRLR   [Node 019] Interview stage completed: OverwriteConfig
2022-10-31T16:12:39.769Z CNTRLR   [Node 019] Interview completed
2022-10-31T16:12:39.769Z CNTRLR   [Node 019] The node is ready to be used
I have also tried an re-interview with a working Qubino mini dimmer.
This gives me the following:
2022-10-31T16:18:12.004Z CNTRLR « [Node 014] received response for protocol info:
                                  basic device class:    Routing Slave
                                  generic device class:  Multilevel Switch
                                  specific device class: Multilevel Power Switch
                                  node type:             End Node
                                  is always listening:   true
                                  is frequent listening: false
                                  can route messages:    true
                                  supports security:     false
                                  supports beaming:      true
                                  maximum data rate:     100000 kbps
                                  protocol version:      3
vs
2022-10-31T16:12:20.262Z CNTRLR « [Node 019] received response for protocol info:
                                  generic device class:  Binary Switch
                                  specific device class: Binary Power Switch
                                  node type:             End Node
                                  protocol version:      3
Yes, that seems to be the main issue. There are also a lot of failed commands and timeouts. This device is not reporting support for Multilevel Switch CC (dimmer), thus information about that functionality is never queried.
2022-10-31T16:12:20.599Z CNTRLR « [Node 019] node info received
                                  supported CCs:
                                  · Z-Wave Plus Info
                                  · Binary Switch
                                  · Association
                                  · Association Group Information
                                  · Transport Service
                                  · Version
                                  · Manufacturer Specific
                                  · Device Reset Locally
                                  · Configuration
                                  · Meter
                                  · Notification
                                  · Powerlevel
                                  · Security
                                  · Security 2
                                  · Supervision
There was an error reading parameter 6. Depending on the version of the device, either param 5 or 6 will control dimming vs. toggle functionality. You might try refreshing the value and seeing if it’s set correctly. Parameter 5 looks OK, so not sure if that’s the actual issue.
Thanks for pointing me in an direction for troubleshooting. I have installed the ZwaveJS UI addin. This might be a clue for the next step.
Driver: Node 019 supports Security S0, but the S0 network key was not configured. The interview might not include all functionality. (ZW0212)
What i’m trying to do now is retrieve the parameters of a working Qubino and compare them with the one not working. As i’m not sure how to refresh or set the parameters
For future reference:
I have contacted Qubino about this issue. My devices are running older firmware (v20.0). The way to add the dimmer functionality is to change the parameter (5) to dimmer mode. After the change you have to exclude and include the device in your network.
For devices with current firmware, an re-interview wil work without any problems.
@freshcoast: Thanks for your support :slight_smile:
Ah, that requirement is known, I should have mentioned it. :sweat_smile: The default value is set to dimmer, so I assumed it was that way to start with. Glad it’s solved, and that it was addressed in new firmware.
