I have brought a zigbee Tuya scene switch from AliExpress. I am able to configure it.
But I see no entities except battery. This will have 12 scenes ( 3 scenes for each switch).
can someone help me on how this can be achieved and if someone tried it ?
I am using Zigbee Home Automation . This is a Sonoff zigbee bridge flashed with Tasmota if that matters.
I am new to HA and trying to understand , I believe I need to search the events like entities. But I do not see any as you mentioned. Could you help me here?
You need to scroll down in that page to Listen to events and you need to listen to zha_event. Then click on your switch’s buttons.
If you go to Configuration > Automation and you add a new automation, you will be able to select your switch as the device to use. Then you should see all possible actions under trigger
