In the past few weeks I’ve noticed that my automations (motion sensors in the garage and outside for lighting) have been slow to respond if they respond at all. Maybe 5-10 seconds sometimes. I wanted to add some new sensors to a few automations and noticed I can’t add anything. I’ve tried exporting everything, renaming the node red directory and reimporting them and I still have the same issues…
Heres my node red logs. I don’t see anything thats seems wrong.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 13.4.0
You are running the latest version of this add-on.
System: Home Assistant OS 9.2 (amd64 / generic-x86-64)
Home Assistant Core: 2022.10.5
Home Assistant Supervisor: 2022.10.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/customizations.sh
cont-init: info: /etc/cont-init.d/customizations.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
cont-init: info: running /etc/cont-init.d/node-red.sh
patching file nodes/ui_base.html
Hunk #1 succeeded at 1164 (offset 633 lines).
up to date, audited 1 package in 122ms
found 0 vulnerabilities
cont-init: info: /etc/cont-init.d/node-red.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nginx (no readiness notification)
services-up: info: copying legacy longrun nodered (no readiness notification)
s6-rc: info: service legacy-services successfully started
[15:18:56] INFO: Starting Node-RED…
start
node $NODE_OPTIONS node_modules/node-red/red.js “–settings” “/etc/node-red/config.js”
21 Oct 15:18:57 - [info]
Welcome to Node-RED
21 Oct 15:18:57 - [info] Node-RED version: v3.0.2
21 Oct 15:18:57 - [info] Node.js version: v16.16.0
21 Oct 15:18:57 - [info] Linux 5.15.72 x64 LE
21 Oct 15:18:57 - [info] Loading palette nodes
21 Oct 15:18:58 - [info] Dashboard version 3.2.0 started at /endpoint/ui
21 Oct 15:18:58 - [info] Settings file : /etc/node-red/config.js
21 Oct 15:18:58 - [info] Context store : ‘default’ [module=memory]
21 Oct 15:18:58 - [info] User directory : /config/node-red/
21 Oct 15:18:58 - [warn] Projects disabled : editorTheme.projects.enabled=false
21 Oct 15:18:58 - [info] Flows file : /config/node-red/flows.json
21 Oct 15:18:58 - [warn] Encrypted credentials not found
21 Oct 15:18:58 - [info] Server now running at http://127.0.0.1:46836/
21 Oct 15:18:58 - [info] Starting flows
21 Oct 15:18:58 - [info] Started flows
[15:18:58] INFO: Starting NGinx…
21 Oct 15:19:03 - [info] [server:Home Assistant] Connecting to http://supervisor/core
21 Oct 15:19:03 - [info] [server:Home Assistant] Connected to http://supervisor/core
