No entities listed in node red
Hi All,
So I installed the nodered add on yesterday, but It doesn’t seem to find any of my HA entities?
I’ve reinstalled the addon, performed multiple restarts, even tried re-adding the homeassistant server, (with both the addon tick box selected and manual IP entry). each time the issue remains.
nodered SSL disabled
I’m running home assistant on a raspberry pi 4 8gb with SSD, and have been doing so reliably for over a year now
everything is up to date
HA
I’m also not getting any logs in nodered
HA2
Any help greatly appreciated
Posting solution for others
Sorry All,
Stupidity got the better of me there.
I assumed that HA was up to date because it wasn’t prompting me with available updates.
I have now found that I can manually update via the CLI terminal using the commands below:
  1. ha os update
  2. ha core update
ensure you take a backup beforehand
once I did that, and gave it a little time, I now see all entities in nodered
