I have a problem and despite reading the forums, I can’t find a solution.
I have Home Assistant (HA) running on a Raspberry Pi (IP 192.168.1.76).
I have a Synology NAS with IP 192.168.1.20.
My router is at 192.168.1.1.
I have a domain provided by Synology: truc.synology.me.
I have forwarded external ports 443, 80, and 5001 to my Synology.
I can access my Synology without any issues by typing its address from my mobile device (outside the Wi-Fi network). The routing is functionnal.
I have set up the reverse proxy on Synology with an SSL certificate, and it works fine locally.
However, it doesn’t work when I try accessing it from the outside.
Does anyone have any ideas?
Here is my configuration.yaml
Please help !
"Sorry for putting everything in a single image. As a new user, I can only post one image at a time.
> Images of text are a horrible thing, which is why the pinned post asks you not to do that.
No problem! I’m not familiar with the customs of forums. I’m not a geek, just a knowledgeable user
> Did you check HA’s log file? Did you check the proxies log file?
In the log of HA i found nothing (i checked Home Assistant Core, Supervisor, Host and DNS).
It record no information when i try to log from external.
And in the synology, i absolute don’t know where to found it. I checked on the logs, but no information from proxy. I checked i SSH but no files, exept if i install a ProxyServer package that i don’t need at all…
