gregeeh
November 29, 2022, 5:30am
1
Hi all,
I have HA 2022.11.4 installed in a docker container on my NAS and I cannot connect to it externally.
In HA Network Settings I have it set to http://xxxx.duckdns.org:8123 but none of the Android Devices are able to connect when not connected to WiFi.
Port Forwarding is setup on my pfSense Router to forward port 8123 → HA-IP-Address:8123,
Is there anything else I should be doing to get this to work?
nickrout
(Nick Rout)
November 29, 2022, 5:43am
2
Have you set up duckdns itself?
gregeeh
November 29, 2022, 5:58am
3
duckdns has been setup for years on the pfSense Router.
EDIT: Open Port testing tools show xxx.duckdns.org has port 8123 open.
nickrout
(Nick Rout)
November 29, 2022, 9:12am
4
And in the android companion app what do you have the url set to?
And can you connect from a web browser from an external connection?
gregeeh
November 29, 2022, 7:22pm
5
Thanks for your replies, much appreciated.
https://i.imgur.com/DbyBDaX.png
Yes, that works just fine.
nickrout
(Nick Rout)
November 29, 2022, 8:14pm
6
Quite simply your companion app cannot connect from that URL as it uses your local IP. When the android is not on wifi it cannot see your internal IP addresses.
gregeeh
November 29, 2022, 9:23pm
7
Thanks for your reply.
So is there no way to make the companion app connect using the Wifi when at home and use the duckdns address when not connected to the WiFi?
nickrout
(Nick Rout)
November 29, 2022, 9:44pm
8
The picture you posted shows how to. The Internal connection URL is for your home wifi and the home assistant url is for everything else.
gregeeh
November 29, 2022, 10:29pm
9
Fantastic, thanks very much.
