I use Home Assistant, core installation.
For external access, Nabu Casa is my friend
When I open a terminal and use avahi-browse to read how Home Assistant announces itself using MDNS, I see external URL is empty.
$ avahi-browse -rtl _home-assistant._tcp
+ enp3s0 IPv4 Maison _home-assistant._tcp local
= enp3s0 IPv4 Maison _home-assistant._tcp local
hostname = [xxx.local]
address = [IP4_addr]
port = [8123]
txt = ["requires_api_password=True" "base_url=http://<ipv4>:8123" "internal_url=http://<ipv4>:8123" "external_url=" "version=2023.9.2" "uuid=xxx" "location_name=Maison"]
As I specified, I use Home Assistant Cloud for external access so the external URL should be my Nabu Casa URL.
When I checked some months ago, external URL was set.
Unfortunately I donβt find anything which could help to know when this issue begun.
What could cause this issue?
