I just noticed, (because I rarely look at the History Tab) History items are either not appearing or are simply not there. I say not appearing because I’m not getting the normal “No state history found.”, unless I select the Yesterday date filter (new db)
I’ve uninstalled MariaDB and then reinstalled (and setup) the addon. I also let the system run on the default sqlite db to see if the problem was related to MariaDB and the results where the same.
Thanks for the suggestion, I tried and it did not make a difference in Firefox. However I took your suggestion a little further and tried Chrome and sure enough it works fine in Chrome.
If you have FF installed, would you mind checking? I’m using version 97.0.1 (64-bit)
