Hi there.
I am running HA as a Docker Container and it keeps throwing this error up, over and over, from Portainer:
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/hacs/__init__.py", line 12, in <module>
from aiogithubapi import AIOGitHubAPIException, GitHub, GitHubAPI
File "/usr/local/lib/python3.12/site-packages/aiogithubapi/__init__.py", line 20, in <module>
from .device import GitHubDeviceAPI
File "/usr/local/lib/python3.12/site-packages/aiogithubapi/device.py", line 14, in <module>
from .client import GitHubClient
File "/usr/local/lib/python3.12/site-packages/aiogithubapi/client.py", line 27, in <module>
from .legacy.client import AIOGitHubAPIClient as LegacyAIOGitHubAPIClient
File "/usr/local/lib/python3.12/site-packages/aiogithubapi/legacy/client.py", line 15, in <module>
from ..helpers import async_call_api
File "/usr/local/lib/python3.12/site-packages/aiogithubapi/helpers.py", line 8, in <module>
from sigstore.verify import (
File "/usr/local/lib/python3.12/site-packages/sigstore/verify/__init__.py", line 54, in <module>
from sigstore.verify.models import (
File "/usr/local/lib/python3.12/site-packages/sigstore/verify/models.py", line 30, in <module>
from sigstore._internal.rekor import RekorClient
File "/usr/local/lib/python3.12/site-packages/sigstore/_internal/rekor/__init__.py", line 19, in <module>
from .client import RekorClient
File "/usr/local/lib/python3.12/site-packages/sigstore/_internal/rekor/client.py", line 35, in <module>
from sigstore._internal.tuf import TrustUpdater
File "/usr/local/lib/python3.12/site-packages/sigstore/_internal/tuf.py", line 28, in <module>
from tuf.ngclient import Updater
File "/usr/local/lib/python3.12/site-packages/tuf/ngclient/__init__.py", line 6, in <module>
from tuf.api.metadata import TargetFile
Error grabbing logs: invalid character '\x00' looking for beginning of value
I really do not know where to start, figuring out what the issue is and how to fix it.
Any help would be much appreciated.
