No integrations available after install. HA connection to github is broken
New user with a new install and upgrade to latest core 2021.11.1, supervisor 2021.10.8, os 6.6, using raspberry pi installer on a rpi4.
No integration’s available, log says
ERROR (MainThread) [supervisor.store.repository] Can’t remove built-in repositories!
Found item #2955 which looks like the same problem but there isn’t a clear solution to fix this. Since this is for some zwave switch controls and zwave isn’t available without an integration there is nothing I can do with home assistant until this is fixed.
That has nothing to do with integrations. Add-ons maybe, but not integrations.
I would check for other errors or warnings though, likely there’s more there to help us help you.
The title mentions.integration, not addons. As a new user those sound the same. The other error message in the logs shows that connection to github for integrations fails. What other information can I provide?
You probably want to read the glossary.
What other error? You didn’t share it
The problems were caused by a bad sd card. The same problems appeared after reinstalling to the same card but did not occur after installing to a new card. Verified the card was bad by testing on a separate machine.
