No integrations
I’m planning to run HomeAssistant in docker on a seperate VM because my pi doesn’t have enough performance.
When i install a test HA on docker, the integrations page isn’t showing any new integrations.
Only a few discovered integrations.
Is this a common bug or am i missing something?
Many Thanks
Did you look if you have on the bottom right the (+) button… try to click there.
I think that they cleaned up to not have all that are not interesting for you…
Great!
I was confused why the integrations showing on my rpi and not in the docker container.
But the (+) button showed the solution!
