Hi there,
I’ve successfully installed DuckDNS and LetsEncrypt. It is working from the external name of https://mydomain.duckdns.org just fine.
My Internal and External URLs are set as follows on the General page:
External: https://mydomain.duckdns.org
Internal: http://homeassistant.iot.mydomain.org:8123
But now, my internal name/url http://homeassistant.iot.mydomain.org:8123 doesn’t work any longer.
This happened as soon as I restarted with this added to the configuration.yaml file.
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
So by adding that, I no longer have internal access? I tried the following and none of them work from my internal network:
http://homeassistant.iot.mydomain.org:443
http://(internal-IP)
http://(internal-IP):443
http://(internal-IP):8123
Could someone tell me if I’m missing something in my config or if this is the way it is now that I’ve added those certificates and this is part of the lockdown to make it secure?
