Hi
I rebooted my PC and it’s back to missing local ip address and I get the following screen. Help please?
Hi
Your command is missing an - in front of IPv6 it should be two – instead you used one -
Hi Frits 1980,
thank you for a speedy reply.
I’ve corrected the command. When I enter it I get a pause and then the following response (screen shot attached)?
Any thoughts?
I am connected with an Ethernet cable
Hi frits1980,
I’m up and working again. I unplugged the Ethernet cable and I got the world icon in the network of the task bar on my PC. I connected to my wifi then plugged the Ethernet back in and ran the command and walla it worked.
