Dear
I have an odroid n2+ were my home assistant was working. Suddenly i have no web access anymore. Also no ip adress is assigned to the odroid.
I cannot see any ip adress assigned from my DHCP server.
I see the orange led blinking on the board directly. No green led. I tried to reinstall the complete version 6.6 again on the board with the micro-usb. Even after reinstall no ip adress.
Any suggestions are welcome.
Tromperie
(Frank Collins)
December 8, 2021, 7:15pm
2
Did you connect a monitor to see whether it is booting properly?
aceindy
(Aceindy)
December 8, 2021, 7:29pm
3
or tried another LAN cable?
Dear.
Thanks for replying on my topic.
The OS seems to start up normally. This is the screen when i’m connecting a monitor.
I also tried new cables.
Try to assign a fixed IP to your device in the router
I tried another router (netgear) instead of my router from the provider in Belgium. Still not work.
I cannot assign a fixed ip because the router does not recognize the odroid device :
Physically there is connection to the router (led on router side is active).
To clarrify, the device you see in the devices is my own laptop.
Nobody ? My issue is still not solved
Seems it is not getting an ip, at least there is non showing in the screenshot
Did you tried another cable?
myle
(StePhan McKillen (Other kiwi Here))
December 15, 2021, 11:05am
10
I use Fing on my phone when I can’t find the IP
I tried already other network scanning tools without success. Also Fing did not gave me the odroid box. Could this be hardware related ?
Yes i did already tried other cables.
Tromperie
(Frank Collins)
December 16, 2021, 8:37am
14
I would install a different operating system to test whether it is hardware or software. Are you using a SD card or another boot medium?
francisp
(Francis)
December 16, 2021, 9:24am
15
Telenet, Orange, Proximus, Edpnet, Scarlet ?
aceindy
(Aceindy)
December 16, 2021, 9:55am
16
Hmm…did some searching and this looks very much like it is a known Odroid issue
Post script update.
Spoke with odroid.co.uk . They echoed @cogneato ’s observation that earlier versions of HA OS could sometimes ship with no space on the drive due to it having been turned on for testing, and then turned off. @cogneato noted that the newer version of HA OS has fixed that, but odroid asked which O/S Version I’m running (HassOS 4.20 - they installed it, after all) and said that they’d had a unit back this morning with that very issue.
I don’t have the means to update HassOS with…
