Hi. I’ve been trying to setup presence detection on HA for a few days now, but everytime I do so HA never creates a known_devices.yaml file in the config directory. Why? Should I create it manually? I’m using Asuswrt to track through the router. My config for the device tracker is below. I also have discovery turned on if that makes any difference. Why isn’t it creating the file?
I have done this. Not only did a few of my family members leave a while ago, but i also disconnected my phone from the wifi and then reconnected it. Still nothing
Yes, in fact. In the log it says: homeassistant.components.device_tracker.asuswrt: Unexpected response from router: password refused. However, the password works when logging into the routers config page at 192.168.1.1. Why would this be?
password (Optional): The password for your given admin account (use this if no public key is given).
pub_key (Optional): The public key for your given admin account (instead of password).
Make sure to use one or the other, but not both. If using password. Make sure “Allow SSH Password Login” is enabled.
You could also try disabling “Brute Force Detection” if enabled to see if that helps.
Anyways, I did only specify one, not both. I put the password to the router into the config page for HA. In the router page, Allow password is enabled and i have it set to port 22. Is there something i’m missing? The password does have a $ symbol in it, could that be tricking HA?
Nevermind. I got it to work by turning telnet on in the router and switching the protocol to telnet. Not sure why ssh wont work though. SSH is more secure so id prefer to use that.
Reusing an old thread if anyone encounters the same issue. I had the same problem when using an SSH-key, @r0gu3patri0t comment on using root as username instead of my actual admin account was the solution.
