I am trying to write an automation that references the last_changed state of a input_boolean helper, however, the result of the template is alway none.
Example template is:
{% for entity in label_entities("Interface Helper") %}
{% if is_state(entity, 'on') %}
{{entity}}
{{states.entity['last_changed'] }}
{% endif %}
{% endfor %}
entity above reports correctly. However {{states.entity[‘last_changed’] }} is reporting none. If I sub in the full input_boolean entity id, it still has none, however a non-helper devices shows last changed correctly.
Do the helpers have access to last_changed and I am just configuring wrong? or can this not be accessed?
