I found the following errors:
1:
Logger: homeassistant.components.recorder.core
Quelle: components/recorder/core.py:686
Integration: Recorder (Dokumentation, Probleme)
Erstmals aufgetreten: 29. Oktober 2024 um 10:09:50 (1 Vorkommnisse)
Zuletzt protokolliert: 29. Oktober 2024 um 10:09:50
Recorder._run threw unexpected exception, recorder shutting down
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/cursor.py", line 1136, in fetchall
rows = dbapi_cursor.fetchall()
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 686, in run
self._run()
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 791, in _run
self._run_event_loop()
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 835, in _run_event_loop
self._pre_process_startup_events(startup_task_or_events)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 868, in _pre_process_startup_events
self.event_data_manager.load(non_state_change_events, session)
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/event_data.py", line 57, in load
self._load_from_hashes(hashes, session)
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/event_data.py", line 99, in _load_from_hashes
for data_id, shared_data in execute_stmt_lambda_element(
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 199, in execute_stmt_lambda_element
return executed.all()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/result.py", line 1379, in all
return self._allrows()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/result.py", line 548, in _allrows
rows = self._fetchall_impl()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/cursor.py", line 2135, in _fetchall_impl
return self.cursor_strategy.fetchall(self, self.cursor)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/cursor.py", line 1140, in fetchall
self.handle_exception(result, dbapi_cursor, e)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/cursor.py", line 1081, in handle_exception
result.connection._handle_dbapi_exception(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2353, in _handle_dbapi_exception
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
(Background on this error at: https://sqlalche.me/e/20/4xp6)
2:
Logger: homeassistant.components.recorder.util
Quelle: components/recorder/util.py:202
Erstmals aufgetreten: 29. Oktober 2024 um 10:09:49 (3 Vorkommnisse)
Error executing query: (sqlite3.DatabaseError) database disk image is malformed (Background on this error at: https://sqlalche.me/e/20/4xp6)
