I try to follow the proper instalation from the linux installation process.
once I arrive to this next step:
“Once you have installed the required Python package, it is now time to install Home Assistant Core!”
pip3 install homeassistant==2024.6.2
Then I have this error: “No matching distribution found for homeassistant==2024.6.2”
I’ve been looking everywhere in Google and nothing.
Version 3 does not say much. Debian bookworm comes with Python 3.11, so I suspect Armbian Bookworm to come with Python 3.11 too.
And that is the problem, to run homeassisant core 2024.6.2 you need Python 3.12 installed.
actually I did, many times and once runing there are those 2 error from Home Assistant:
"Unsupported system - AppArmor issues : System is unsupported because AppArmor is working incorrectly and add-ons are running in an unprotected and insecure way.
Unsupported system - CGroup version: System is unsupported because the wrong version of Docker CGroup is in use."
And I was surprise as it is for Edge2 but still have errors?
Now I try to just insting it a different way…still issues.
Who have mentioning buying Orange ?, if anything id recommend Green, for you.
However installing HomeassistanOS, you should be able to barebone, if it’s supported hardware, if it’s not why go through the hassle in the first place ?
Not sure about your “definition” of Faster +20 hours(with nothing but problems) sounds not fast, in my opinion, how many hours did you spend on installing an unstable/buggy-release of Bookworm Khadas Edge2 linux 6.8.11 ?
