beevee
(BV)
July 14, 2020, 1:26am
1
I got an ESP module to detect door opening and closing and publish to MQTT on the HA server.
I was able to configure the MQTT binary_sensor and it nicely shows on Homekit as Contact Sensor. If only I could nicely convert the MQTT payload to the sensor!! Im facing the No matching payload error as denoted below in the logs.
My doorsensor1.yaml
- platform: mqtt
state_topic: "maindoor"
qos: 0
value_template: >
{% if value_json.Door %}
{{'ON'}}
{% else %}
{{'OFF'}}
{% endif %}
device_class: window
Error in the log file:
No matching payload found for entity: main_door_sensor with state topic: maindoor. Payload: {"time":"1493829297829","Door":False}, with value template Template("{% if value_json.Door %} {{'ON'}} {% else %} {{'OFF'}} {% endif %} ")
Error parsing value: 'value_json' is undefined (value: {"time":"1493829297829","Door":False}, template: {% if value_json.Door %} {{'ON'}} {% else %} {{'OFF'}} {% endif %} )
I was referring to this post while writing the template.
Any suggestions?
francisp
(Francis)
July 14, 2020, 2:03am
2
A binary_sensor expects ‘ON’ or ‘OFF’
- platform: mqtt
qos: 0
value_template: >
'ON'
{% else %}
'OFF'
{% endif %}
beevee
(BV)
July 14, 2020, 11:18pm
3
Ok. I Changed the code to send just ON or OFF. Im still facing the same issue.
Error parsing value: 'value_json' is undefined (value: , template: {{ value_json.Status }})
Home Assistant has started!
No matching payload found for entity: main_door_sensor with state topic: maindoor. Payload: , with value template Template("{{ value_json.Status }}")
Here is the payload Im sending :
{"time":"Tue Jul 14 20:17:38 2020\n","Status":"OFF"}
However if I changed the payload to just this it works!! So Im guessing Im missing some JSON processing component/addon?
config:
- platform: mqtt
qos: 0
value_template: "{{ value_json }}"
device_class: door
Payload:
"ON"
beevee
(BV)
July 15, 2020, 11:21pm
4
I finally managed to solve this myself! With the new version, there is a lot of changes. Here is the solution:
- platform: mqtt
state_topic: "outdoor_metrics"
unit_of_measurement: "°F"
value_template: "{{ value_json.Temp }}"
json_attributes_topic: "outdoor_metrics"
json_attributes_template: "{{ value_json | tojson }}"
- platform: mqtt
unit_of_measurement: "%"
device_class: humidity
value_template: "{{ value_json.Humidity }}"
You see how tojson gets called? Thats the trick. Here is the payload for this.
{"Temp": "82.5","Humidity": "51.65%"}
