No matter what I install I have to reload the page im on
Hi sence 8.1 im having huge problems installing add on both from the official store and from “Francks Store” the apps installs but I am unable to start the app After I reload the page the app has started when I look at the logs everthing went fine no errors I can’t make any configurations (page is blank) after I reload the page the app has started and I can configure the configurations page… I tried to install MQTT broker after couple of restartes and reinstall I could not add MQTT config from integrations The MQTT broker installed find but I had to reload the page for it to start. The MQTT integration would not connect to the broker no matter what user or ip-adr / core- I filled in the form… Any other having the same / similar problem … Im on a total new install from scratch as my backup didn’t help on the MQTT problem.
Sounds more like a browser cache issue.
Try to clear the browsers cache or try another browser, that you have not used before or have cleared its cache on.
Hi WallyR. thank you for your reply … I thought the same, I cleared the cache or history as it is called in Safari many times and shut down safari too I didn’t help how ever I will try if the problem comes back when I have to install some thing again to use Crome browser the next time
