I need some help understanding my situation!
I started my home automation long before learning about Home Assistant. I have six web enabled devices scattered throughout the property controlling and monitoring much of my home automation. These devices https://controlbyweb.com/ provide digital and analog inputs, relays and one wire sensors. I monitor temperature and humidity, control dehumidification, open and close garage doors and list goes on. Last year I decided to incorporate this information into Home Assistant using Modbus to bring the information into HA. Everything always works just as expected without any problems.
Last night I experienced a power outage at my residence due to a storm. This is the first outage since integrating the Control By Web devices into HA. Just fyi, I live in a rural area, When my power goes out so does my internet. The cable distribution amplifier in my area loses power when my power goes out, NO internet. I have a backup generator that automatically comes online when utility power is lost. All of my network devices and computers are on a UPS so they do not see any interruption in power during the transition to generator power. My local LAN continues to function as you would expect. I can communicate with all of my network devices locally including my six Control By Web devices. My home network is up and running normally. Just no internet. When I opened HA I noticed right away that ALL of my 40 plus modbus entities were reporting unavailable! What’s going on here? So first thing I start pinging my devices. Everything is alive and well. I navigate to the devices local web interfaces and can see that all are working normally.
Can someone please explain to me why modbus integration in HA does not function properly when I loose my WAN connection? Seems pretty fishy to me since this should be local communication between the local device and my HA instance running locally on the same network. As soon as my internet came back online modbus began communicating normally again.
