Since few days, all my history-graph cards in lovelace says “No state history found”, and the history tab is endlessly loading. I have first think it was a problem with my database, I use a docker container with Postgresql. But if I do a sql request on the events or state table, I can see the last events are still recorded.
I have see nothing in the logs of the home assistant container.
If I try to see the logs in lovelace, the log tab is endlessly loading.
I wanted to remove the last modification I’ve made in my config (on automations, so it’s probably not the cause of the problem, but we never know), and I can’t check the configuration. it loads without ever stopping.
I’ve try to drop the tables in Postgresql, and to comment the line in onfiguration.yaml so home assistant create a new sqlite database.
But the problems are still here.
I had the very same issue and ended up deleting (renaming) /config/home-assistant_v2.db . I lost all history, but at least everything works now.
I think It’s the same to drop the tables in postgresql.
I have try to comment the connection line to postgresql in configuration.yaml, and restart home assistant. So home-assistant_v2.db have been created. The problem was still here.
I have deleted home-assistant_v2.db and restart home assistant.
The problems are stille here.
I don’t think the problem is from the Database.
Even if my configuration.yaml contains only the following lines :
homeassistant:
latitude: !secret latitude
longitude: !secret longitude
elevation: 35
unit_system: metric
time_zone: Europe/Paris
http:
frontend:
I can’t access to Configuration > Integrations (the loading never end)
I can’t access to Configuration > logs (the loading never end)
I can’t check the configuration (it never end)
And there is a thing that never end in Configuration > Customizations (but I never go there, so I don’t know what it is)
