Piece of free advice
When you have you setup your HASS just the way you want it you will want to do the following.
Clone your SD card!
Once everything is set up the way you want it, shut down the Pi and remove the SD card. Insert the SD card into your computer.
Start Win32DiskImager.
In “Image File”, enter the path of for your image file.
Example, C:\Users\DamnImGood\images\perfecthass.img -
Under “Device”, select your SD card.
Click the “Read” button to start cloning your card.
When ready, eject your SD card. You can put it back in your Raspberry Pi.
Keep that IMG file in a safe place or two. I have a copy on my NAS and one on a seperate mobile HDD nect to a copy of my configuration.yaml and known_devices.yaml.
When you want to write it back put the SD card in the computer select image file to WRITE and you have a perfect copy written back.
No more reinstalling from scratch.
