Uuwee96
(Uuwee96)
February 28, 2025, 5:17pm
1
for some reason I can’t find any official add-ons in the Add-on Store. Add-ons that I have already installed report that they have been removed from their repository. The Matter Server add-on does not work anymore, because it apparently does not exist anymore.
This happened after a restart of my HA VM in Proxmox. I did not install any updates to the OS or any add-ons before restarting. Even restoring from a backup when everything was working did not change anything.
I am running HA OS in a Proxmox VM with the following versions:
HA OS 14.2
HA Core 2025.2.5
HA Supervisor 2025.02.4
What might be the problem here?
Thanks in advance, Uwe
francisp
(Francis)
February 28, 2025, 6:38pm
2
Most of the time it’s Github timing out.
I also started experiencing this today after rebooting Proxmox as well. For me, it was the following repo: https://github.com/jeremywillans/hass-addons/php-nginx
Same issue here. I’ve created a GitHub issue for home assistant core.
opened 07:42AM - 01 Mar 25 UTC
integration: matter
### The problem
Home assistant cannot find the matter integration and server pl… ugin any more. I cannot reinstall, and it don’t know what to do else. Issue started with connection losses every few hours.
### What version of Home Assistant Core has the issue?
core-2025.2.5
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Matter
### Link to integration documentation on our website
_No response_
### Diagnostics information
_No response_
### Example YAML snippet
```yaml
### Anything in the logs that might be useful for us?
```txt
### Additional information
_No response_
