I’ve had no luck on changing theme. Please assist. As in picture I have no option to change themes.
schoey
2
You need to install them via hacs
tom_l
3
No you don’t. They can also be manually created.
However this is another issue where the option to select a theme does not appear in a person’s profile.
Ernie, did you recently delete a theme?
Did not delete a theme bit did delete a card installed via Hacs.
This is new install after pi3 stopped working.
Themes installed via hacs and .yaml configure
tom_l
6
Do you have this in your configuration.yaml file:
frontend:
themes: !include_dir_merge_named themes
Correct, I did edit config.yaml
tom_l
8
Does this service exist in Developer Tools / Services?
frontend.set_theme
I have this same problem. Identical to above. Yes to all questions. Still can’t see any themes. Any help is appreciated!!
