I have installed HomeAssistant on t640.
I used Generic x86-64 - Home Assistant with
Created a “live operating system” then “Write the image to your boot medium”.
Balena Etcher stopt working after 32%.
Reboot t640 then Home Assistant was started, nice.
Profile Switched Advanced Mode on.
I used Honeywell Lyric - Home Assistant
All wend well but got error “Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble”
I wanted to install HACS installed Terminal & SSH(9.7.1)
In de terminal I typed the install commando:
wget -O - https://get.hacs.xyz | bash -
wget: bad address ‘get.hacs.xyz’
So why can my system not find this address?
I tried commando
ping yahoo.com
ping: bad address ‘yahoo.com’
looked in forum for information
changed nameserver to 8.8.8.8 because I have no dnsserver running
make it static
ha network info
connected: true
enable: true
method: static
type: internet
ha network reload
ha supervisor restart
When i started up the system today Home Assistant ask if I want to install 2023.10.4.
Now I have system with versions:
Home Assistant 2023.10.4
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0
I think the 2 installations I tried are related. There is a connection with internet but not completely.
What can do there be done to get it work?
