No problem with the negative water consumption 🚰
We will not use that amount of water :stop_sign:
Finding it takes some effort as the list where you can find the wrong value only shows a very limited range, so use history graph to pinpoint the exact time, and then check around that period.
Has anybody solved this? Removing manualy each day values in the database is not a permanent solution - there has to be some other way, like additional helper or someting…
