No reconoce adaptador bluetooth en un portatil
hola tengo instalado el home assistant OS en un portatil Acer, antes lo tuve con linux y el home assista corriendo por debajo, y el bluetooth funcionaba.
ahora e instalado el home assistant os y no encuentra ningun adaptador, alguien sabe que puedo hacer
gracias
English
hello I have installed the home assistant OS on an Acer laptop, before I had it with linux and the home assist running underneath, and bluetooth worked. Now and installed the Home Assistant OS and does not find any adapter, anyone knows what I can do Thank you
Hi, I’ve installed the home assistant OS on an Acer laptop, before having it with Linux and home assistance running underneath, and bluetooth worked. Now I installed the Home Assistant operating system and I can’t find any adapter, anyone knows what I can do Thanks
I have tried with two diff dongles so far (ASUS BT400 and avantree DG45) and it does not work either… im losing patience here.
