No Recorder after update from Core 2024.5.5 to 2024.6.3
Home Assistant on bare metal Intel NUC
Now my system runs Core 2024.5.5, Supervisor 2024.06.0, Operating System 12.4
Everything OK. Made full backup
Update to Core 2024.6.3.
Recorder does not do anything.
Restored full backup.
Everything OK, still running Core 2024.5.5
Than recovered the database sqlite → no errors
Did the same as above.
Backup-Upgrade-Restore
Log:
2024-06-19 03:21:54.122 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 136, in session_scope
    yield session
  File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 1502, in migrate_states_context_ids
    "context_parent_id_bin": _to_bytes(context_parent_id),
  File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 1471, in _context_id_to_bytes
    return ulid_to_bytes(context_id)
TypeError: Argument 'ulid_str' has incorrect type (expected str, got bytes)
2024-06-19 03:21:54.135 ERROR (Recorder) [homeassistant.components.recorder.core] Error while processing event StatesContextIDMigrationTask()
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 906, in _guarded_process_one_task_or_event_or_recover
    self._process_one_task_or_event_or_recover(task)
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 926, in _process_one_task_or_event_or_recover
    task.run(self)
  File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 370, in run
    not instance._migrate_states_context_ids()  # noqa: SLF001
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1292, in _migrate_states_context_ids
    return migration.migrate_states_context_ids(self)
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 643, in wrapper
    return job(instance, *args, **kwargs)
2024-06-19 03:21:54.586 ERROR (Recorder) [homeassistant.components.recorder.core] SQLAlchemyError error processing task CompileMissingStatisticsTask()
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 925, in _process_one_task_or_event_or_recover
    self._commit_event_session_or_retry()
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1191, in _commit_event_session_or_retry
    self._commit_event_session()
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1217, in _commit_event_session
    session.execute
