No response from CCTV camera if video feed is set to RTSP or RTMP?
I’m trying to set up some Reolink CCTV E1 Outdoor and Reolink Doorbell camera around my house, and I’ve found something a little unusual and I’m not sure if I’m doing something wrong, or if it’s a bug.
All of the camera support RTSP and RTMP, I’ve had them running through other software using it so know that they’re set up correctly.
If I go to the Reolink integration and select either RTSP or RTMP I not only don’t get video but I also get no response from any sensor or entity. Home Assistant can see that they all exist but the motion sensors never trigger, there is no history recorded, and I can’t toggle any of the options. It’s like the camera were set up but have dropped off of the network. Which I initially thought was what had happened.
If I set the integration to FLV, everything runs like a dream. The sensors are active and I can change the settings again.
Curiously, this only happens with the E1 Outdoors, the doorbell doesn’t seem to care how it connects.
Has anyone ever encountered this before, or am I just doing something wrong with the setup?
Things seem to be running OK with FLV, but I’d like to know why I’m having this problem.
