Hi - before posing, i have searched but struggled to find a solution.
My HA stopped working on my synology - so installed a new docker and latest image but I cant find any option to restore from backup - bit of a noob, can anyone assist please?
I’m assuming that is a Docker/Container install?
If so see footnote 2 in the table here: Installation - Home Assistant
You need to manually restore by copying the entire /config folder from your backup to your new install.
Hi Tom - yes it is a Docker/Container install. I originally did a backup from my Pi which stopped working for some reason & could not log in so tried this restore process.
Let me try again.
As the footnote I linked to says, there is no UI restore function for Container installs.
You have to extract the /config folder from the backup and copy it to your new system.
