No sensor data from Weidmann Elektronik IR USB reader
I have a technical or a knowhow problem with my Weidmann Elektronik IR Read/Write USB for my Smart Meter.
I installed it via: EDL21 - Home Assistant
an added this to the configuration.yaml:
  - platform: edl21
    serial_port: /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307Z7Z3-if00-port0
The HA log says:
Detecting HardwareAction.ADD serial hardware /dev/ttyUSB0 - /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307Z7Z3-if00-port0
But I cant see any new sensor in my HA instance. I restarted, changed config etc. but cant find a “Stromzaehler” sensor.
Is it the device getting no data or do I need to something more to get the sensor started?
Thanks for your help
closed, found a solution for myself
Hi, can you tell me how you have solved your problem.
The edl21 integration isn’t working.
Telling others how you fixed it, would be what forums are for. :wink:
Any news?
