No sound when installed on Mac mini with VMware Fusion
Hi guys,
I have successfully installed HA OS in a virtual machine with VMware Fusion 13 on my Mac Mini M1 (apple silicon), almost everything are working perfectly except playing sound (I tested with the Spotify connect and there is no sound at all).
I checked the ha audio logs , there are some errors shown with pulseaudio:
s6-rc: info: service alsa-init: starting
[17:20:16] INFO: Adjust ALSA mixer settings for /dev/snd/control*
cat: can't open '/sys/class/sound/control*/device/id': No such file or directory
s6-rc: info: service alsa-init successfully started
s6-rc: info: service pulseaudio: starting
W: [pulseaudio] main.c: Running in system mode, but --disallow-module-loading not set.
W: [pulseaudio] main.c: Home directory of user 'root' is not '/var/run/pulse', ignoring.
W: [pulseaudio] caps.c: Normally all extra capabilities would be dropped now, but that's impossible because PulseAudio was built without capabilities support.
W: [pulseaudio] main.c: OK, so you are running PA in system mode. Please make sure that you actually do want to do that.
W: [pulseaudio] main.c: Please read http://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/ for an explanation why system mode is usually a bad idea.
E: [pulseaudio] upower.c: Get() failed: org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
s6-rc: info: service pulseaudio successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service pulseaudio: stopping
[15:21:32] INFO: Service restart after closing
s6-rc: info: service pulseaudio successfully stopped
s6-rc: info: service alsa-init: stopping
s6-rc: info: service alsa-init successfully stopped
s6-rc: info: service alsa: stopping
s6-rc: info: service alsa successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/filesystem.sh
cont-init: info: /etc/cont-init.d/filesystem.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service alsa: starting
s6-rc: info: service alsa successfully started
[17:22:19] INFO: Adjust ALSA mixer settings for /dev/snd/control*
E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer: unit failed.
any one has some idea to solve this sound issue?
Did you figure this out? I have the same issue running HA OS in UTM on an M2 Mac Mini.
Edit: I filed a feature request
Edit 2: we don’t have the drivers but they’re coming
