No SSH-connection possible
I installed HA on my Rpi4B this afternoon and I succeeded :wink:
After that I spent hours trying SSH to get to work, with no luck ;-(
I have installed and configured the addOna and used this procedure (https://www.digitalocean.com/community/tutorials/how-to-create-ssh-keys-with-putty-to-connect-to-a-vps) to generate a keyPair.
After that I configured the public Key configured in HA resulting in this log:
Is this OK?
Then I created a profile in the putty-client with a reference to the private key, but I can’t get a connection.
kk2
I don’t completely understand the config of the “network” part? Is there something necessary here?
kk3
Or is something completely different going on. I need some suggestions.
I think the Network part should be fine. I configured the add-on to use a password, so I can’t comment on that part. Make sure you are logging in as root
After the last “Terminal & SSH” update I have lost the possiibility to login via SSH, wit the same symptoms as in the opening post. Everything worked fine before (login using certificate). I can still login using Web UI, thus.
I had the same problem!
In the configuration, under Network, I have restored 22 (also on my configuration was visible the text ‘disabled’ under Host).
After a restart of the SSH addon, all seems works correctly.
Gigios solution also works for me, many thanks :rainbow: :stuck_out_tongue_winking_eye:
Rgds, Ko
