I was unable to add an Aeotec Zwave Door/Window sensor with “Add Node” but it worked with “Add Secure Node”- even though this isn’t a secure device?
Now the device appears in my Zwave config node listing. However, opening and closing the door doesn’t change the state- it is always off. Is there any way to read the status of the Door sensor? I am not getting anything from binary_sensor.ecolink_doorwindow_sensor_sensor
From configuration.yaml
zwave:
usb_path: /dev/ttyACM0
network_key: “00x25, REDACTED , 0x28”
debug: true
autoheal: true
For Node information:
averageRequestRTT: 0 averageResponseRTT: 0 battery_level: 99 capabilities: beaming,routing friendly_name: Ecolink Door/Window Sensor is_awake: false is_failed: false is_info_received: true is_ready: false is_zwave_plus: false lastRequestRTT: 0 lastResponseRTT: 0 manufacturer_name: Ecolink max_baud_rate: 40000 node_id: 7 node_name: Ecolink Door/Window Sensor product_name: Door/Window Sensor query_stage: CacheLoad receivedCnt: 0 receivedDups: 0 receivedTS: 2018-09-09 18:35:02:014 receivedUnsolicited: 0 retries: 0 sentCnt: 1 sentFailed: 1 sentTS: 2018-09-09 18:35:11:092 wake_up_interval: 14400
From the Zwave logs:
2018-09-09 18:35:02.020 Info, Node007, Node Identity Codes: 014a:0001:0002
2018-09-09 18:35:02.020 Info, Node007, NoOperation::Set - Routing=true
2018-09-09 18:35:02.020 Detail, Node007, Queuing (NoOp) NoOperation_Set (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xc9
2018-09-09 18:35:02.020 Detail, Node007, Queuing (Query) Query Stage Complete (CacheLoad)
2018-09-09 18:35:02.020 Detail, Expected reply was received
2018-09-09 18:35:02.020 Detail, Message transaction complete
2018-09-09 18:35:05.411 Detail, Node007, Notification: NodeAdded
2018-09-09 18:35:05.425 Detail, Node007, Notification: NodeProtocolInfo
2018-09-09 18:35:05.428 Detail, Node007, Notification: EssentialNodeQueriesComplete
2018-09-09 18:35:05.443 Detail, Node007, Notification: ValueAdded
2018-09-09 18:35:05.455 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2018-09-09 18:35:05.456 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2018-09-09 18:35:05.479 Detail, Node007, Notification: ValueAdded
2018-09-09 18:35:05.504 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2018-09-09 18:35:05.533 Detail, Node007, Notification: ValueAdded
2018-09-09 18:35:11.091 Info, Node007, Sending (NoOp) message (Callback ID=0x0c, Expected Reply=0x13) - NoOperation_Set (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xc9
2018-09-09 18:35:11.100 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-09 18:35:11.100 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-09 18:35:15.316 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x01, 0x01, 0xa6, 0x41
2018-09-09 18:35:15.316 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2018-09-09 18:35:15.316 Info, Node007, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-09-09 18:35:15.316 Info, Node007, Node 7 has been marked as asleep
2018-09-09 18:35:15.317 Info, Node007, Node not responding - moving controller command to Wake-Up queue: Delete All Return Routes
2018-09-09 18:35:15.317 Info, Node007, Node not responding - moving controller command to Wake-Up queue: Assign Return Route
2018-09-09 18:35:15.317 Info, Node007, Node not responding - moving QueryStageComplete command to Wake-Up queue
2018-09-09 18:35:15.317 Detail, Node007, Notification: Notification - NoOperation
2018-09-09 18:35:15.323 Detail, Node007, Notification: Notification - Node Asleep
