Hey folks,
first topic
I am currently having problems with the PN532 and an ESP32.
The project is based on the standalone tag reader from adonno.
However, I need more IO inputs for buttons. Hence the ESP32.
Buttons work like charm.
Using I2C, I can sometimes read RFID tags after flashing. but only a few times. As a test, I have now connected the RFID reader via SPI. here is an attached LOG:
INFO Reading configuration /config/esphome/tagreader.yaml...
INFO Starting log output from tagreader-kinder.local using esphome API
INFO Successfully connected to tagreader-kinder.local
[13:16:01][I][app:102]: ESPHome version 2021.9.3 compiled on Oct 20 2021, 10:44:47
[13:16:01][I][app:104]: Project adonno.tag_reader version 1.6
[13:16:01][C][wifi:501]: WiFi:
[13:16:01][C][wifi:361]: SSID: [redacted]
[13:16:01][C][wifi:362]: IP Address: 192.168.178.61
[13:16:01][C][wifi:364]: BSSID: [redacted]
[13:16:01][C][wifi:365]: Hostname: 'tagreader-kinder'
[13:16:01][C][wifi:369]: Signal strength: -59 dB ▂▄▆█
[13:16:01][V][wifi:371]: Priority: 0.0
[13:16:01][C][wifi:373]: Channel: 1
[13:16:01][C][wifi:374]: Subnet: 255.255.255.0
[13:16:01][C][wifi:375]: Gateway: 192.168.178.1
[13:16:01][C][wifi:376]: DNS1: 192.168.178.1
[13:16:01][C][wifi:377]: DNS2: 0.0.0.0
[13:16:01][C][spi:081]: SPI bus:
[13:16:01][C][spi:082]: CLK Pin: GPIO18 (Mode: OUTPUT)
[13:16:01][C][spi:083]: MISO Pin: GPIO19 (Mode: INPUT)
[13:16:01][C][spi:084]: MOSI Pin: GPIO23 (Mode: OUTPUT)
[13:16:01][C][spi:085]: Using HW SPI: YES
[13:16:01][C][template.switch:058]: Template Switch 'TagReaderKinder Buzzer Enabled'
[13:16:01][C][template.switch:058]: Icon: 'mdi:volume-high'
[13:16:01][C][template.switch:059]: Restore State: YES
[13:16:01][C][template.switch:060]: Optimistic: YES
[13:16:01][C][template.switch:058]: Template Switch 'TagReaderKinder LED enabled'
[13:16:01][C][template.switch:058]: Icon: 'mdi:alarm-light-outline'
[13:16:01][C][ledc.output:032]: LEDC Output:
[13:16:01][C][ledc.output:033]: Pin GPIO26 (Mode: OUTPUT)
[13:16:01][C][ledc.output:034]: LEDC Channel: 0
[13:16:02][C][ledc.output:035]: Frequency: 988.0 Hz
[13:16:02][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'next'
[13:16:02][C][gpio.binary_sensor:016]: Pin: GPIO17 (Mode: INPUT_PULLUP, INVERTED)
[13:16:02][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'previous'
[13:16:02][C][gpio.binary_sensor:016]: Pin: GPIO21 (Mode: INPUT_PULLUP, INVERTED)
[13:16:02][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'play_pause'
[13:16:02][C][gpio.binary_sensor:016]: Pin: GPIO16 (Mode: INPUT_PULLUP, INVERTED)
[13:16:02][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'volume_up'
[13:16:02][C][gpio.binary_sensor:016]: Pin: GPIO22 (Mode: INPUT_PULLUP, INVERTED)
[13:16:02][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'volume_down'
[13:16:02][C][gpio.binary_sensor:016]: Pin: GPIO4 (Mode: INPUT_PULLUP, INVERTED)
[13:16:02][C][fastled:019]: FastLED light:
[13:16:02][C][fastled:020]: Num LEDs: 1
[13:16:02][C][fastled:021]: Max refresh rate: 400
[13:16:02][C][logger:193]: Logger:
[13:16:02][C][logger:194]: Level: VERBOSE
[13:16:02][C][logger:195]: Log Baud Rate: 115200
[13:16:02][C][logger:196]: Hardware UART: UART0
[13:16:02][C][light:097]: Light 'TagReaderKinder LED'
[13:16:02][C][light:099]: Default Transition Length: 0.0s
[13:16:02][C][light:100]: Gamma Correct: 2.80
[13:16:02][C][pn532:344]: PN532:
[13:16:02][C][pn532:356]: Update Interval: 1.0s
[13:16:02][C][pn532_spi:156]: CS Pin: GPIO27 (Mode: OUTPUT)
[13:16:02][C][rtttl:017]: Rtttl
[13:16:02][C][status:034]: Status Binary Sensor 'TagReaderKinder Status'
[13:16:02][C][status:034]: Device Class: 'connectivity'
[13:16:02][C][ota:029]: Over-The-Air Updates:
[13:16:02][C][ota:030]: Address: tagreader-kinder.local:3232
[13:16:02][V][pn532_spi:029]: Writing data: 00.00.FF.04.FC.D4.4A.01.00.E1.00 (11)
[13:16:02][V][pn532:243]: Reading ACK...
[13:16:02][V][pn532_spi:037]: Waiting for ready byte...
[13:16:02][V][pn532_spi:062]: Reading data...
[13:16:02][V][pn532_spi:068]: Read data: 01.00.00.FF.00.FF.00 (7)
[13:16:02][V][pn532:254]: ACK valid: YES
[13:16:02][V][pn532_spi:073]: Reading response
[13:16:02][V][pn532_spi:084]: Not ready yet...
[13:16:02][V][pn532_spi:087]: Timed out waiting for readiness from PN532!
[13:16:02][V][pn532:265]: Turning RF field OFF
[13:16:02][V][pn532_spi:029]: Writing data: 00.00.FF.04.FC.D4.32.01.00.F9.00 (11)
[13:16:02][V][component:207]: Component pn532 took a long time for an operation (0.17 s).
[13:16:02][V][component:208]: Components should block for at most 20-30ms.
[13:16:02][C][api:135]: API Server:
[13:16:02][C][api:136]: Address: tagreader-kinder.local:6053
[13:16:02][C][api:140]: Using noise encryption: NO
[13:16:03][V][pn532_spi:029]: Writing data: 00.00.FF.04.FC.D4.4A.01.00.E1.00 (11)
[13:16:03][V][pn532:243]: Reading ACK...
[13:16:03][V][pn532_spi:037]: Waiting for ready byte...
[13:16:03][V][pn532_spi:062]: Reading data...
[13:16:03][V][pn532_spi:068]: Read data: 01.00.00.FF.00.FF.00 (7)
[13:16:03][V][pn532:254]: ACK valid: YES
[13:16:03][V][pn532_spi:073]: Reading response
[13:16:03][V][pn532_spi:084]: Not ready yet...
[13:16:03][V][pn532_spi:087]: Timed out waiting for readiness from PN532!
[13:16:03][V][pn532:265]: Turning RF field OFF
[13:16:03][V][pn532_spi:029]: Writing data: 00.00.FF.04.FC.D4.32.01.00.F9.00 (11)
Config:
# Insert your SSID and Your PWD after inital setup
wifi:
networks:
- ssid: !secret wlan_ssid # Enter your WiFi SSID here. Example: `ssid: 'your_network_name'`
password: !secret wlan_password # Enter your wifi password here. Example: `password: 'abcde123456'`
# ap:
# ssid: ${devicename}
# Enable the captive portal for inital WiFi setup
#captive_portal:
substitutions:
devicename: tagreader-kinder
friendly_name: TagReaderKinder
mediaplayer: media_player.familienzimmer
esphome:
platform: ESP32
board: nodemcu-32s
#nodemcu-32s
# This will allow for (future) project identification,
# configuration and updates.
project:
version: "1.6"
# If buzzer is enabled, notify on api connection success
on_boot:
priority: -10
then:
- wait_until:
api.connected:
- logger.log: API is connected!
- rtttl.play: "success:d=24,o=5,b=100:c,g,b"
- light.turn_on:
brightness: 100%
red: 0%
green: 0%
blue: 100%
flash_length: 500ms
- switch.turn_on: buzzer_enabled
- switch.turn_on: led_enabled
# Define switches to control LED and buzzer from HA
switch:
name: "${friendly_name} Buzzer Enabled"
icon: mdi:volume-high
optimistic: true
restore_state: true
name: "${friendly_name} LED enabled"
icon: mdi:alarm-light-outline
optimistic: true
restore_state: true
api:
services:
- service: rfidreader_tag_ok
then:
- rtttl.play: "beep:d=50,o=5,b=100:e6"
- service: rfidreader_tag_ko
then:
- rtttl.play: "beep:d=8,o=5,b=100:b"
- service: play_rtttl
variables:
song_str: string
then:
- rtttl.play: !lambda 'return song_str;'
# Enable logging
logger:
level: VERBOSE
# Enable OTA upgrade
ota:
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
pn532_spi:
cs_pin: GPIO27
update_interval: 1s
on_tag:
then:
- homeassistant.tag_scanned: !lambda 'return x;'
- if:
condition:
switch.is_on: buzzer_enabled
then:
- if:
condition:
switch.is_on: led_enabled
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
flash_length: 500ms
# Define the buzzer output
output:
- platform: ledc
pin: GPIO26
# Define buzzer as output for RTTTL
rtttl:
output: buzzer
binary_sensor:
- platform: status
#Next Track
- platform: gpio
pin:
number: GPIO17
mode: INPUT_PULLUP
inverted: true
filters:
- delayed_on_off: 100ms
on_press:
- then:
- homeassistant.service:
service: media_player.media_next_track
entity_id: ${mediaplayer}
#Previous Track
- platform: gpio
pin:
number: GPIO21
mode: INPUT_PULLUP
inverted: true
filters:
on_press:
then:
service: media_player.media_previous_track
#Play/Pause
- platform: gpio
pin:
number: GPIO16
mode: INPUT_PULLUP
inverted: true
filters:
on_press:
then:
service: media_player.media_play_pause
#Volume up
- platform: gpio
pin:
number: GPIO22
mode: INPUT_PULLUP
inverted: true
filters:
on_press:
then:
service: media_player.volume_up
#Volume down
- platform: gpio
pin:
number: GPIO4
mode: INPUT_PULLUP
inverted: true
filters:
on_press:
then:
service: media_player.volume_down
# Configure LED
light:
- platform: fastled_clockless
chipset: WS2812
pin: GPIO25
default_transition_length: 10ms
num_leds: 1
flash_transition_length: 500ms
rgb_order: GRB
restore_mode: ALWAYS_OFF
RFID Reader connected like:
